Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Labs /
Lab 1 - Output<^< Introduction and Lesson Plan | Course Index | 2. Delay >^>(:nl:) ->'''''1. Introduction''''' The first exercises on microcontrollers in any course are always on outputs. What better way to visualize output levels than with LEDs. ->'''''2. Setting up the equipment''''' ![]() ->'''''3. Hardware settings'''''
->'''''4. Flowcode and download settings'''''
->'''''5. Software learning objectives''''' Output, binary code training, compiling a program to the PIC, clocking the PIC, PIC microcontroller basics. ->'''''6. Hardware learning objectives''''' LED’s, logic output levels, Multiprogrammer basics, current limiting resistor between PIC and LEDs. ->'''''7. Instructions''''' Construct the system shown from E-blocks. In the course navigate to the ‘Flowcode step-by-step’ and review the section on Digital outputs (step 2). To understand Masking you will need to review the section on Decisions (step 7). In the course you will also find the sections on Clocking your PIC, and about PIC microcontroller basics useful. The descriptions of the Multiprogrammer board and the led board are in the E-blocks section. Make use of the Help-function in Flowcode to get the info you need. During these exercises you are going to send different 8-bit codes to port B of your Microcontroller. You'll also learn how to change the logic level of only one single pin of port B. In RC mode the clock is quite slow. In XTAL mode it is very fast. ->'''''8. Labs'''''
:L1-B1: Use a single output icon that lights all of the LED's of Port B. :L1-B2: Alter the icon parameters so it puts only the odd LEDs of Port B 'on' :L1-B3: Now put only the even LEDs of Port B 'on'. :L1-B4: Now put the High nibble (bits 4 to 7) of Port B 'on' :L1-B5: In steps 1 to 4 you used a decimal number between 0-255 that you sent to Port B, start using the Hexadecimal notation to send a value to Port B. Repeat the ex. 1-4 with Hex notation. :L1-B6: Put only the LED on PB7 'on' by sending an 8-bit value to this port. :L1-B7: Put only the LED on PB7 'on' by using the 'Single bit' output method. :L1-B8: Put only the LED on PB7 'on' by using the 'Masking' output method. :L1-B9: Write a program with at least 20 Outputs icons that writes different values to Port B, one after the other, and review what the result is in simulation. Use all of the 4 different methods in this exercise: Hexadecimal, Decimal, Single bit and Masking. Slow down the simulation speed from 'as fast as possible' to the speed that fits you best to visualize the different output values. :L1-B10: Download the program to the PIC. Configure both the Multiprogrammer and flowcode to work in slow RC mode. Review the section on 'clocking your PIC' if this it not clear to you. Restart the program in the PIC over and over again by pressing the reset button on the Multiprogrammer board. :L1-I11: Draw up the full circuit diagram of the PIC with 8 LEDs on Port B, including the clocking circuit, the reset circuit, VDD and VSS connected to the PIC and the correct current limiting resistors connected between LED and PIC. If you made a circuit of this drawing, and connected power to it, it should perform exactly the same as the E-blocks system in front of you. Schematics in the E-blocks section will come in handy when you do this task. (:nl:)(:table style="clear:both":)
Page last modified on May 14, 2013, at 01:49 PM
