Recent Changes - Search:
<^< Busses | Course index | The Clock Circuit >^>
Clocking Your PICmicro Devices *
Introduction * The Clock Circuit * Clock Settings * Clock Confusion
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Introduction
<^< Busses | Course Index | The Clock Circuit >^>(:nl:)
Every microcontroller needs a clock signal to operate. Internally to the device the clock signal controls the speed of operation of the device and each passing clock cycle synchronises the operation of the various internal hardware blocks. There are several decisions to be made concerning clocking your chip and before downloading a program to a PICmicro device you need to understand the choices and make some decisions. In this section we will address the issue of clocking and the choices you can make. (:nl:)(:table style="clear:both":)
Page last modified on August 19, 2011, at 01:27 PM
