Recent Changes - Search:
<^< How to use this Course | Course index | What is a PICmicro? >^>
Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course *
Acronyms Used and Course Conventions
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Acronyms Used And Course Conventions
<^< How to use this Course | Course Index | What is a PICmicro? >^>(:nl:)
The following abbreviations are made use of in this course:
:'''ADC''':Analogue to Digital Converter
:'''ALU''':Arithmetic Logic Unit
:'''ASCII''':American Standard Code for Information Interchange
:'''CPU''':Central Processing Unit
:'''EEPROM''':Electrically Erasable Programmable Read Only Memory
:'''EPROM''':Erasable Programmable Read Only Memory
:'''GND''':Ground
:'''Hex''':Hexadecimal
:'''IDC''':Insulation Displacement Connector
:'''I/O''':Input / Output
:'''ISP''':In-System Programming
:'''JPEG''':Joint Picture Expert Group (standard for images)
:'''LCD''':Liquid Crystal Display
:'''LED''':Light Emitting Diode
:'''LVP''':Low Voltage Programming
:'''LDR''':Light Dependant Resistor
:'''LSB''':Least Significant Bit
:'''MSB''':Most Significant Bit
:'''NVRAM''':Non-Volatile Random Access Memory
:'''PIC''':Peripheral Interface Controller
:'''PROM''':Programmable Read Only Memory
:'''PSU''':Power Supply Unit
:'''RAM''':Random Access Memory
:'''RV1''':Resistor-Variable 1
:'''SPI''':Serial Programmable Interface
:'''XTAL''':Crystal
:'''ZIF''':Zero Insertion Force
:'''+V''':positive supply voltage
In this course we will use the following conventions:
:'''Matrix Multimedia products are capitalised on the first word''':Multiprogrammer, Prototype board, Flowcode
:'''Flowcode menu instructions will be presented like this''':File > Open
:'''All acronyms will be fully spelt out the first time they are mentioned''':EPROM (Electrically Programmable Read Only Memory)
:'''Where a string in a dialogue box is mentioned in the text then it should be in single quotes''': Change the value in the 'Delay value or variable' text box
:'''We will use European circuit symbols''':
(:nl:)(:table style="clear:both":)
Page last modified on May 14, 2013, at 07:52 AM
