Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login What Is a PICmicro<^< Acronyms Used and Course Conventions | Course Index | Microcontrollers >^>(:nl:) The name PIC, (Peripheral Interface Controller), refers to a group of microcontrollers, produced by Arizona Microchip. ![]() PIC16F84 PICmicro microcontroller As its name suggests, a microcontroller is a tiny device used to control other electronic devices. They are found in a huge range of products: * Your car engine is controlled by one. * So are the anti-lock brakes and the climate control. * Any device that has a remote control almost certainly contains a microcontroller. * TVs, VCR's, digital cameras, mobile phones, printers, microwave ovens, dishwashers, washing machines... So what is this wonderful device? A microcontroller is a digital integrated circuit, and consists of: * central processing unit * memory * input ports * output ports (:nl:)(:table style="clear:both":)
Page last modified on August 19, 2011, at 10:03 AM
