Recent Changes - Search:
<^< A/D Conversion | Course index | Introduction >^>
About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture ## PORT A ## PORT B ## PORT C ## PORT D ## PORT E ## Memory in the 16F1937 ## ALU ## Timer 1 ## Timer 0 ## RB0 Interrupt ## Port B Interrupt ## A/D Conversion ##
Busses
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< A/D Conversion | Course Index | Introduction >^>(:nl:)
Largely simplified block schematic to demonstrate the bus structure of the PIC 16F1937 Architecture:
Busses:
* A PICmicro is a typical Harvard-type Microcontroller. * This means that there is a separate bus for Instructions and one for Data. * The data bus is 8-bit wide and connects every block and port together. * The instruction bus is 14 bit wide and transports 14 bit long instructions from the program memory to the ALU. (:nl:)(:table style="clear:both":)
Page last modified on September 20, 2011, at 10:43 AM
