Recent Changes - Search:
<^< Port B Interrupt | Course index | Busses >^>
About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture ## PORT A ## PORT B ## PORT C ## PORT D ## PORT E ## Memory in the 16F1937 ## ALU ## Timer 1 ## Timer 0 ## RB0 Interrupt ## Port B Interrupt ##
A/D Conversion ## Busses
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
A / D Conversion
<^< Port B Interrupt | Course Index | Busses >^>(:nl:)
Largely simplified block schematic to demonstrate where the A/D Converter is located in the PIC 16F1937 Architecture:
A / D:
* This 16F1937 PICmicro microcontroller has 14 pins that have an extra A/D function. * This PICmicro controller has only one single 10-bit A/D converter. * This implies that these 14 analogue inputs can't all be read at the same time. * A built in analogue switch is the answer to this problem. * In Flowcode you can select which of the 14 analogue inputs you want to sample. * After this 'sample' instruction, the analogue switch is set to the correct input and this analogue input is converted to a 10-bit binary value. * In Flowcode, you can select to only use the 8 MSB's of this 10-bit value by using the 'GetByte' instruction, or you can select to use the full 10 bits by selecting the 'GetInt' instruction. The 10 bits will fill up the 10 LSB's of the selected 16-bit integer variable. * After this, you can select an other analogue input that needs to be read.
(:nl:)(:table style="clear:both":)
Page last modified on May 13, 2013, at 02:54 PM
