Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture ## PORT A ## PORT B ## PORT C ## PORT D ## PORT E ## Memory in the 16F1937 ## ALU ## Timer 1 ## Timer 0 ## RB0 Interrupt ## Port B Interrupt ## A/D Conversion ## Busses Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PIC16F1937 Architecture<^< Different Types of PICmicro | Course Index | PORT A >^>(:nl:)
At this point in a traditional programming course you would be introduced in some detail to the various internal circuit blocks of the PICmicro device. You would need this information to write code for the PICmicro in C or assembly code. However Flowcode takes care of the details of PICmicro architecture for you so we will not cover this subject here. However you will need to have an understanding of the input and output connections of the PICmicro and the amount of memory available to you. These topics are covered in this section. You should be aware that we cover only a subset of the available internal circuit blocks of this microprocessor. (:nl:)(:table style="clear:both":)
Page last modified on September 29, 2011, at 09:09 AM
