Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Backup and Restore(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) (:Summary:background information and some basic backup and restore procedures:) This page has some background information on making backups and explains some basic *nix backup and restore procedures. IntroductionYour wiki installation contains some unique data in the following directories: local/ Local configuration scripts
cookbook/ Recipes obtained from the Cookbook
pub/ Publicly accessible files
wiki.d/ Wiki pages
uploads/ Uploaded files (attachments)
A good backup plan will include periodically archiving these directories — or at bare minimum Simple Backup and Restore (*nix)When it comes to backup, simpler is better. Since the pmwiki distribution is very small (about 1/4 megabyte), it's simplest to just archive the distribution files along with the data. Making a Backup ArchiveThe following *nix command, executed from the parent directory of your wiki's directory, will put a complete backup archive of your site in your home directory. -> tar -zcvf ~/wiki-backup-`date +%Y%m`.tar.gz wiki/ Restoring the Backup ArchiveSimple MethodYour site can be restored and running in under 30 seconds with -> tar -zxvf ~/wiki-backup-200512.tar.gz find wiki/uploads/ -type d |xargs chmod 777 find wiki/wiki.d/ -type d |xargs chmod 777 A Slightly-More-Secure MethodThe simple restore commands above will give you world-writable files and directories. You can avoid world-writable permissions by letting PmWiki create directories with the proper attributes (ownership and permissions) for you. Start with -> tar -zxvf ~/wiki-backup-200512.tar.gz rm -rf wiki/wiki.d rm -rf uploads chmod 2777 wiki/ Now upload a file in each group that had uploads. If your site doesn't have uploads, just visit your site once so the wiki.d/ directory will be created. Finish your installation with -> chmod 755 wiki/ tar -zxvf ~/wiki-backup-200512.tar.gz DetailsThe commands on this page assume your site is in a directory called "wiki/". The test backup was made in December, 2005 so it's named accordingly. Your site will only have an uploads/ directory if uploads are enabled. The backup command uses a date stamp (YYYYMM) in the filename. If you automate the command via cron you'll wind up with monthly snapshots of your site. You can get a daily snapshot by appending %d to the date command ( MiscellaneousBackup via FTPDownload and install a ftp client like Filezilla # Using the ftp client connect to the server where you host pmWiki using ## the IP address (ex: 123.234.56.67) or the ftp name (ex: ftp.myhost.com) ## supply your account name (ex: mylogin) and password (ex: myp4ssw0rd) # Move to your pmWiki directory (ex: @@/usr/mylogin/web/wiki/@@ or @@/tahi/public_html/pmwiki@@ ) # Select the folder you want to backup as explained before (probably either only the data or the whole wiki directory) ** for data you will want to backup both the directories *** @@wiki.d@@ for user page data *** @@pmwikiuploads@@ (or @@uploads@@) for your attachments (uploads) ** for system you will want, at a minimum, to backup both the directories *** @@local@@ for configuration data *** @@pub@@ for local CSS and skins customisations # Download them to a local folder # Use 7zip or a similar software to build an archive of this backup You can also very easily sync your FTP directories with your hard disc via this command line:
-> Alternatively, you can also mirror your FTP directories with lftp:
-> Using rsyncSee Cookbook:BackupWithRsync and Cookbook:TwoWayMirroringWithRsync. See Also* A thread [gmane.org] on the pmwiki-users mailing list. * A Backup Pages recipe in the cookbook. * A Backup HTML Zip recipe in the cookbook. (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:BackupAndRestore, and a talk page: PmWiki:BackupAndRestore-Talk. >><< |
Page last modified on August 30, 2019, at 12:00 PM
