Recent Changes - Search:
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
GroupHeaders and GroupFooters
(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :)
authors (intermediate)
(:nl:)(:Summary: Group Header and Group Footer page usage:)
(:Audience: authors (intermediate) :) Every WikiGroup can have GroupHeader and GroupFooter pages that contain markup that should be included at the beginning or end of each page within the group. This feature is useful for:
* adding a disclaimer or heading to all of the pages of a group * defining custom WikiStyles that may be used for all pages in a group * replacing the default headers and/or footers for pages in a group (e.g., using (:noheader:) and or (:nofooter:) -- see PageDirectives).
To create a group header, just create a new page called YourGroup.GroupHeader. Group headers allow authors to create groups with custom headers and footers without having to coordinate with a wiki administrator.
The default GroupHeader or GroupFooter can be suppressed on an individual page (such as a group's HomePage) by using the (:nogroupheader:) and (:nogroupfooter:) markups ''on that page''.
If a generic GroupHeader is used in one wikigroup (say, the Site wikigroup), then the code can be easily duplicated in the GroupHeader of any other group by using (:include Site.GroupHeader:). See IncludeOtherPages.
If you want a header or footer to appear when you print a page (action '''print'''), simply create a page called YourGroup.GroupPrintHeader or YourGroup.GroupPrintFooter and fill it with your markup.
You can also set the variable $GroupPrintHeaderFmt and $GroupPrintFooterFmt in the same way as $GroupHeaderFmt and GroupFooterFmt in order to change the header used when action=print.
See also * Cookbook:All group header * Cookbook:Wiki footer
>>faq<<
Q: How do I set the same header or footer for all pages/groups? A: The header and footer for each page are controlled by the variables $GroupHeaderFmt and $GroupFooterFmt. If your site-wide header and footer pages are Site.SiteHeader and Site.SiteFooter, you can add this in config.php:
### If you use Site.SiteHeader and Group.GroupHeader
$GroupHeaderFmt = '(:include {$SiteGroup}.SiteHeader'
  . ' basepage={*$FullName}:)(:nl:)' . $GroupHeaderFmt;
<:vspace>
### If you use Site.SiteHeader instead of Group.GroupHeader
  . ' basepage={*$FullName}:)(:nl:)';
<:vspace>
### If you use Site.SiteFooter and Group.GroupFooter
$GroupFooterFmt .= '(:nl:)(:include {$SiteGroup}.SiteFooter'
  . ' basepage={*$FullName}:)';
<:vspace>
### If you use Site.SiteFooter instead of Group.GroupFooter
$GroupFooterFmt = '(:nl:)(:include {$SiteGroup}.SiteFooter'
Note that single quotes must be used in the lines above.
See also the Cookbook:AllGroupHeader recipe.
A: Instead of using an additional page, you could set any wiki text in $GroupHeaderFmt, for example:
->$GroupHeaderFmt .= "Global message here."; (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :)
<<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:GroupHeaders, and a talk page: PmWiki:GroupHeaders-Talk. >><<
Page last modified on February 26, 2013, at 04:15 PM
