Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
InterMap(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) author (intermediate)
(:nl:)(:Summary: Interwiki links definition and use:)
(:Audience: author (intermediate) :) The InterMap (also called InterWiki in some other wikis) is a system for defining links between WikiWikiWeb sites that was first developed by UseMod and Meatball (see UseMod:InterWiki and Meatball:InterWiki). The method is to use a word shortcut that stands for a defined path. InterMap links have the form The default intermap.txtThe default ''intermap.txt'' distributed with PmWiki (in the ''scripts/'' directory) includes the following InterMap entries: >>pre<< PmWiki: https://www.pmwiki.org/wiki/PmWiki/ Cookbook: https://www.pmwiki.org/wiki/Cookbook/ Wiki: http://www.c2.com/cgi/wiki? UseMod: http://www.usemod.com/cgi-bin/wiki.pl? Meatball: http://www.usemod.com/cgi-bin/mb.pl? Wikipedia: https://en.wikipedia.org/wiki/ PITS: https://www.pmwiki.org/wiki/PITS/ PmL10n: https://www.pmwiki.org/wiki/Localization/ Path: >><< The page Site.InterMap?You can map your own prefixes in your local page Site.InterMap?. Thus, "PmWiki:Variables" becomes "https://www.pmwiki.org/wiki/PmWiki/" + "Variables", a link to the PmWiki.Variables page on the official PmWiki web site, Wiki:FrontPage is a link to the front page of the first WikiWikiWeb, and Wikipedia:Stonehenge takes you to the Wikipedia article about the famous megaliths in England. Usage in a wiki pageLike other links, you can use the double-bracket syntax to get different link text:
If you want to link just to what the intermap says (e.g. https://www.wikipedia.com/wiki/ for Wikipedia), then do
The special Custom InterMap prefixesThe actual set of InterMap links at any site is defined by the site administrator via the Site.InterMap? page and the ''local/localmap.txt'' file. An intermap entry takes the following format: -> MapPrefix: https://example.com/partial/url/ The InterMap entry can be for any of the link schemes supported by PmWiki. <<? You can create your own InterMap links by doing one or more of the following: * Modify the page called ''Site.InterMap?'' and place entries like the ones above in it. * Create a file called ''local/localmap.txt'' and place entries like the ones above in it. * In a WikiFarm installation you can create a file called ''local/farmmap.txt'' and there place entries like the ones above in it. These prefixes will be common to all the wikis in the farm. * Ensure that there is a space after the colon. Do not edit the file ''scripts/intermap.txt'' directly! If you do, you'll lose your changes when you upgrade PmWiki. Variables and InterMap linksIt's possible to use variables within your InterMap entries. The following
entries create ->
ThisWiki: $ScriptUrl
ThisPage: {$PageUrl}
You can also define InterMap entries where the text of the entry is substituted into the middle of the URL. Just include '$1' in the URL where you want the substitution to take place. For example: -> would cause Tips and tricksIt is possible to document your intermap prefixes directly in the page Site.InterMap?. The extra text will not cause a performance penalty, nor will it break the definition of prefixes. However, be aware that anything matching a line starting with a word and a colon (''':''') will be considered to define a prefix. The order in which various sources are checked for definitions of prefixes
is controlled by the variable Q: Are InterMap names case sensitive?
A: Yes, thus Q: How can I achieve a ''localmap.txt'' mapping with the effect of Q: How can I define an InterMap in PHP? A: Use the following: ->
$LinkFunctions['PmWikiHome:'] = 'LinkIMap';
$IMap['PmWikiHome:'] = 'https://pmwiki.org/wiki/$1';
(:nl:)(:Summary:Trail and talk page links:)
<<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:InterMap, and a talk page: PmWiki:InterMap-Talk. >><< |
Page last modified on May 17, 2018, at 10:24 AM
