Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
SimultaneousEdits(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) < Forms | Documentation Index | Wiki structure > PmWiki has support for handling the case where multiple authors attempt to edit the same page nearly simultaneously. Here's the basic scenario for systems where simultaneous edits are ''not'' handled: * Alice starts to edit a page. * Before Alice saves her edits, Bob requests an edit of the same page, and receives the page text prior to Alice's edits. * Bob finishes with his edits and hits "save". * Alice finishes editing her page, hits "save", and since she was working from a version of the page from before Bob had made his changes, she wipes out Bob's edits in the process. PmWiki's simultaneous edit feature detects when this occurs, and instead of saving Alice's edits PmWiki presents Alice with a message that someone else changed the page while she was editing it. Furthermore, Bob's changes are merged into Alice's copy of the page, with any conflicts highlighted by <<<<<<< and >>>>>>>. Alice can then fix things as appropriate and save the updated page, or, if Alice is lazy, she can just hit "save" a second time and leave it to someone else to fix. The simultaneous edits feature is also invoked whenever someone requests a page preview; thus if a page changes while previewing a page the author gets notification and can see the merged results. How can I test/experiment with this feature?# Open up two browser windows and select the same page to be edited in each window (e.g., try WikiSandbox?action=edit). # In one browser window, make some changes to the page and then save those changes. # In the second browser window, make some different changes to the same page and hit "save". Since the page changed after the edit form was loaded into the second window, there's a potential edit conflict and you'll receive the "edit conflict message". # You can make any adjustments in the second window, and press "Save" again to save the changes. NoticeSome server environments such as Windows and PHP running in safe_mode are unable to use the simultaneous edits capability distributed with PmWiki. See Cookbook:SimultaneousEdits for a solution for these environments. (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) < Forms | Documentation Index | Wiki structure > <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:SimultaneousEdits, and a talk page: PmWiki:SimultaneousEdits-Talk. >><< |
Page last modified on September 10, 2011, at 04:08 PM
