Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
UrlApprovals(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) < Ref count | Documentation Index | Variables > This page explains how to discourage "link spamming" on your wiki site using PmWiki's ''urlapprove.php'' script. This script is already included in PmWiki files, but not activated by default. Using ''urlapprove.php''Occasionally spammers may try to add large number of (sometimes hidden) URLs to pages because they think it will improve their search engine rankings -- which it probably won't. The ''urlapprove.php'' script works against these spammers' purpose by * requiring approval of links to Internet sites before a link to them are created in the wiki, and * allowing you to limit the number of unapproved links that may be added to a page. To enable ''urlapprove.php'', add the following line to a configuration file: -> By default, unapproved links display what ever should be displayed normally (the URL or a text), but not linked and next to it a link (approve links). A click on the link will approve all unapproved URLs on the page, but ''only'' if you are authorized to edit the ''SiteAdmin.ApprovedUrls'' page. You may also pre-approve sites by by adding them directly to the SiteAdmin.ApprovedUrls? page. Limiting unapproved urls per pageYou can limit the number of unapproved links per page. If the limit is exceeded, the page cannot be saved. This is useful because spammers like to write long link lists, which is rare for normal authors. Example: To set the limit to 5 unapproved links, add the following line to a configuration file: -> Note that $UnapprovedLinkCountMax must be set ''before'' including the ''urlapprove.php'' script. Handling of Unapproved LinksYou can also change the disapproval message defined in the $UnapprovedLinkFmt variable, for example: ->
include_once('scripts/urlapprove.php');
$UnapprovedLinkFmt =
"[$[Link requires approval]]<a class='apprlink'
href='\$PageUrl?action=approvesites'>$[(approve)]</a>";
"Link requires approval" is whatever you want to see in place of the unapproved link and "(approve)" is the blue text. Using this feature may prove usefull if you want to always hide the unapproved link. If you wish to totally forbid unapproved links you can use -> Sidebars, headers, footers, included pages or sectionsPlease note that in general you need to go to the sidebar, header, footer pages in order to approve links in them. If pages or sections with unapproved links are included in other pages, or transcluded via a pagelist or a page text variable, you need to approve the links in the original pages. The reason for this is that the approve mechanism only approves links on the ''current'' page. Initial setupAfter initial setup all existing links become unapproved. You need to visit your pages and approve all links, where needed. See AllRecentChanges for a list of all pages that were created on your wiki. Password approval of URLsTo approve external links, an author needs permissions to edit the page SiteAdmin.ApprovedUrls?. Technical tipsURL WhitelistUrls can also be approved by adding them to a "white list",
defined in the variable @@$WhiteUrlPatterns@@,
which is set in the ''local/config.php'' file. -> $WhiteUrlPatterns = "(http://example.com|http://example.net|http://example.org)"; To add all urls from, say New Zealand and Australia, use: -> $WhiteUrlPatterns[] = 'http://[^/]+\\.nz'; $WhiteUrlPatterns[] = 'http://[^/]+\\.au'; Change Approved URLs page nameIf you want to change the default name of ''SiteAdmin.ApprovedUrls'', set the following in ''local/config.php'': -> Previewing the unapproved URLTo see what link is to be approved without editing the page a tool tip can be displayed when the cursor hovers over the (approve links) link that displays the URL. e.g. Example. Add the following setting in your ''local/config.php'': -> $UnapprovedLinkFmt = "\$LinkText<a class='apprlink' href='\$PageUrl?action=approvesites' title='\$LinkUrl'>$[(approve links)]</a>"; ->Some browsers show only the link and not the tooltip title. In this case, you can use the following code to see the unapproved link at the end of the tooltip : -> $UnapprovedLinkFmt = "\$LinkText<a class='apprlink' href='\$PageUrl?action=approvesites&XES_url=\$LinkUrl' title='\$LinkUrl'>$[(approve sites)]</a>"; About rel='nofollow'By default, PmWiki creates external links that are not followed by search engines. Here are release notes from pmwiki-2.0.beta20 (30-Jan-2005): ->''First, the See Also* Blocklist - Blocking postings based on content or IP address * Security - Securing your PmWIki (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) < Ref count | Documentation Index | Variables > <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:UrlApprovals, and a talk page: PmWiki:UrlApprovals-Talk. >><< |
Page last modified on September 04, 2017, at 06:24 AM
