Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
PageHistory(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) < Wiki trails | Documentation Index | Passwords > authors (basic)
(:nl:)(:Summary: History of previous edits to a page:)
(:Audience: authors (basic) :) When PmWiki is called with '?action=diff', it displays a summary of past edits on a page. Each past edit is shown in a box which shows lines added, changed or deleted during that edit in a before & after format. Below each box is a "Restore" link. Clicking the link will open an edit box with the page as it was ''before'' that edit. You can make changes or simply click Save to restore the text. There are two additional options specific to Page''''History: * '''Hide minor edits''' - hides any edit that the author marked as 'minor'. - This is done by adding "&minor=n" to "?action=diff". The default value for this is to show minor edits with "&minor=y" * '''Show changes to output''' - It shows changes to the rendered output (as opposed to the normal display which shows changes to the wiki-markup). This is done by adding "&source=n" to "?action=diff". You can show changes to markup (the default behavior from 2.2.13) with "&source=y". * You can set both by using "?action=diff&source=y&minor=y". In the default mode "Show changes to markup", you can disable word-level highlighting of differences by adding to config.php such a line: A page's history is kept for the number of days given by the Note that a specific page revision isn't removed from the page until the first edit ''after'' the time specified by See also* recent changes special pages * Cookbook:ExpireDiff * Cookbook:LimitDiffsPerPage * Cookbook:ViewDiff * Cookbook:TrackChanges Q: Is there a way to remove page history from page files? A: 1. Administrators can clean page histories using the Cookbook:ExpireDiff recipe. A: 2. Administrators with FTP file access can download individual pages from the wiki.d directory, open them in a text editor, manually remove history, and re-upload the files to wiki.d/ directory. Care must be exercised, when manually editing a page file, to preserve the minimum required elements of the page and avoid corrupting its contents. See PageFileFormat#creating. A: 3. Edit the page. Select ''all'' the contents of the edit text area and cut them to the clipboard. Enter @@delete@@ into the text area and click on the ''save and edit'' button. Select ''all'' the contents of the edit text area and paste the contents of the clipboard over them. Click on the ''save'' button. This will remove all of the page's history up to the final save in which the pasted material is re-added. Q: How can I restrict viewing the page history -> In case of this restriction is set up on a farm, and you want to allow it on a particular wiki, set in your local/config.php : -> < Wiki trails | Documentation Index | Passwords > <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:PageHistory, and a talk page: PmWiki:PageHistory-Talk. >><< |
Page last modified on February 16, 2018, at 06:59 PM
