Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Passwords(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) authors
(:nl:)(:Summary:General use of passwords and login:)(:Audience: authors :)
PmWiki has built-in support for password-protecting various areas of the wiki site. Authors generally want to be able to apply passwords to individual pages or to wiki groups. Wiki Administrators can apply passwords to individual pages, to wiki groups, or to the entire site. Setting an edit password on a page or group (or the entire site) is one of the most common ways to stop spam. As with any access control system, the password protection mechanisms described here are only a small part of overall system and wiki security. As an author editing pages...An author will generally set 3 types of passwords: # to control who can see a page or group, use @@read@@ passwords # to control who can edit a page or group, use @@edit@@ passwords # to control who can alter the passwords used to protect a page or group, use @@attr@@ passwords If required most page actions can be password protected. Protect an individual pageTo set a password on an individual wiki page, add the page action ->@@?action=attr@@ to the page's URL (address) to access its attributes. Using the form on the attributes page, you can set or clear the @@read@@, @@edit@@, or @@attr@@ passwords on the page. In the form you enter the passwords as cleartext; PmWiki encrypts them for you automatically when it stores them. Additional options: * Leaving a field blank will leave the attribute unchanged. * To remove a password from a page (''reverting back'' to the group's or site's default), enter --> @@ clear @@ * To indicate that the page can be edited ''even if a group or site password is set'', enter --> @@ @nopass @@ * To lock a page for everybody but the admin, enter --> @@ @lock @@ * To assign the site's site-wide passwords to the @@read@@, @@edit@@, or @@attr@@ password for the page, enter --> @@ @_site_edit, @_site_read or @_site_upload @@ Protect a wiki group of pagesTo set a password on a wiki group is slightly more difficult -- you just set the passwords on a special page? in each group called ->GroupAttributes? First, you can get to the attributes page for GroupAttributes by entering a URL (address) like
-> Then, using the form on the attributes page, you can set or clear the @@read@@, @@edit@@, or @@attr@@ passwords for the entire group. In the form you enter the passwords as cleartext; PmWiki encrypts them for you automatically. Additional options: * To remove a password from a group (''reverting back'' to the site's default), enter -->@@clear@@ * To indicate that the group can be edited ''even if a site password is set'', enter -->@@@nopass@@ * To lock a group for everybody but the admin, enter -->@@@lock@@ * (Beginning with Ver 2.2.3) To assign the site's site-wide passwords to the @@read@@, @@edit@@, or @@attr@@ password for the group, enter --> @@ @_site_edit, @_site_read or @_site_upload @@ PasswordsPasswords may consist of any combination of characters, except double "quotes" or 'apostrophes'. Passwords with spaces or colons must be entered using quotes, eg "foo bar" or "foo:bar". Obviously longer is better, and on some systems passwords need to have 4 or more characters. Multiple passwordsMultiple passwords for a page, group or site are allowed. Simply enter multiple passwords separated by a space. This allows you to have a read password, a write password, and have the write password allow read/write access. In other words, if the read password is ->alpha and the edit password is ->beta then enter -> Set new read password: alpha beta Set new edit password: beta This says that either ->alpha or ->beta can be used to read pages, but only ->beta may edit. Since PmWiki checks the passwords you've entered since the browser has been opened, entering a read password that is also a write password allows both reading and writing. Protect the sitePasswords can be applied to the entire wiki website in ''config.php''. See passwords administration for details. administrator As an administrator ...You can set passwords on pages and groups exactly as described above for authors. You can also: # set site-wide passwords for pages and groups that do not have passwords # use @@attr@@ passwords to control who is able to set passwords on pages # use @@upload@@ passwords to control access to the file upload capabilities (if uploads are enabled) # use an @@admin@@ password to override the passwords set for any individual page or group # use SiteAdmin.AuthList to view the permissions settings for pages that have permissions set. For more information on password options available to administrators, see PasswordsAdmin. Which password wins?In PmWiki, page passwords override group passwords, group passwords override the ''default'' passwords, and the @@admin@@ password overrides all passwords. This gives a great deal of flexibility in controlling access to wiki pages in PmWiki. The special page? SiteAdmin.AuthList is a page list of all pages with access permissions set. Opening access to pages in protected groups/sitesSometimes we want to "unprotect" pages in a group or site that is otherwise protected. In these cases, the special password ->@@ @nopass @@ is used to indicate that access should be allowed to a page without requiring a password. For example, suppose Main.GroupAttributes has an edit password set, thus restricting the editing of all pages in Main. Now we want Main.WikiSandbox to be editable without a password. Using ->@@clear@@ for the edit password for Main.WikiSandbox ''doesn't unprotect the page'', because the password is being set by the group. Instead, we set the edit password for Main.WikiSandbox to the special value ->@@ @nopass @@ which tells PmWiki to ignore any site-wide or group-level passwords for that page. FAQQ: How can I password protect all the pages and groups on my site? Do I really have to set passwords page by page, or group by group? A: Administrators can set passwords for the entire site by editing the config.php file; they don't have to set passwords for each page or group. For example, to set the entire site to be editable only by those who know an "edit" password, an administrator can add a line like the following to local/config.php: -> @@ For more information about the password options that are available only to administrators, see PasswordsAdmin. Q: I get http error 500 "Internal Server Error" when I try to log in. What's wrong? A: This can happen if the encrypted passwords are not created on the web server that hosts the PmWiki. Solution: Create the passwords on the system with the oldest PHP version and use them on all other systems. Q: How can I create private groups for users, so that each user can edit pages in their group, but no one else (other than the admin) can? A: Modify the edit attribute for each group to id:username, e.g. set the edit attribute in JaneDoe.GroupAttributes to id:JaneDoe. There is a more automatic solution, but it's probably not a good idea for most wikis. Administrators can use the AuthUser recipe and add the following few lines to their local/config.php file to set this up: -> $group = FmtPageName('$Group', $pagename);
$DefaultPasswords['edit'] = 'id:'.$group;
include_once("$FarmD/scripts/authuser.php");
This automatically gives edit rights to a group to every user who has the same user name as the group name. Unfortunately it also gives edit rights to such a user who is visiting a same-named group not just for pages in that group, but for any page on the wiki that relies on the site's default edit password. This can create security holes.
Q: How come when I switch to another wiki within a farm, I keep my same authorization? A: PmWiki uses PHP sessions to keep track of authentication/authorization information, and by default PHP sets things up such that all interactions with the same server are considered part of the same session. Q: Is it possible to test the password level for display and/or if condition? Example: * (:if WriterPassword:) (display Edit link) (:ifend:) A: You can use Q: Can I use A: You can, but usually that's not secure. The recommended strategy is to put secrets in a separate page and restrict all read-related¹ access permissions to those users who are allowed to read the secrets. To display the secrets in another page, you can include (parts of) the secrets page: Users with read access to the secrets will readily see them, whereas other users see nothing or (at your choosing) some other text, e.g. a login link. -> ¹ Currently (version 2.2.99), these are: @@read@@ (would allow include), @@edit@@ (would show the source), @@attr@@ (would allow to obtain read/edit), @@diff@@ (would allow viewing any change), @@source@@ (allows raw source display) The reason why Conditional Markup isn't suitable for access control is that it only applies for rendering wikitext as a web page, and that's just one of many ways to access a page's text. In order to rely on Conditional Markup for protection of secrets, you'd have to restrict all access methods that can circumvent it. To do so, you'd need to keep track of all methods available. In a default installation of PmWiki, some of the easy methods include: Editing a page, viewing its edit history, its source, or including fragments of it into the edit preview of another page. (Preview: To avoid traces in RecentChanges.) However, this list is far from exhaustive, and could easily grow with Recipes? or future versions of PmWiki. (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:Passwords, and a talk page: PmWiki:Passwords-Talk. >><< |
Page last modified on August 30, 2019, at 11:54 AM
