Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
WikiWord(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) A '''WikiWord''' is a set of two or more words run together, where the first letter of each word is capitalized. This syntax is also sometimes referred to as "mixed case" or "camel case". Other descriptions of WikiWords are available from Wiki:WikiWord and Wikipedia:WikiWord. Usage as page titlesWikiWords are used as '''page titles''' in a wiki-based system. Usage as linksIn some wikis (depending on the configuration of PmWiki), a valid '''link''' can be created by writing it as WikiWord. In such PmWiki installations, WikiWords surrounded by [=...=] or preceded by a backquote (`) are not turned into links:
See Links for information about PmWiki's rules for forming links and forming page titles. Enabling WikiWord linksWikiWord links are disabled by default since Pmwiki version 2.1 beta2. To enable WikiWord links you need to set in ''config.php'' See also WikiWord links to non-existent pages without decorationIf you want to display links to non-existent pages without decoration, place the following lines in ''pub/css/local.css'': -> span.wikiword a.createlink { display:none; }
span.wikiword a.createlinktext { border-bottom:none; text-decoration:none; color:inherit; }
Finding WikiWord linksIf you upgraded from an earlier version and want to convert WikiWord links to standard links, the following will help to find those WikiWord links easier by highlighting them. Set in ''config.php'': -> Disabling certain WikiWords linksThe variable (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:WikiWord, and a talk page: PmWiki:WikiWord-Talk. >><< |
Page last modified on October 18, 2016, at 08:29 PM
