Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Links(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) authors (basic)
(:nl:)(:Summary:Multiple mechanisms for creating links:)
(:Audience: authors (basic) :) A key feature of wiki-based systems is the ease of creating hyperlinks (or short '''links''') in the text of a document. PmWiki provides multiple mechanisms for creating such links. Links to other pages in the wikiTo create an internal link to another page, simply enclose the name of the page inside double square brackets, as in PmWiki creates a link by using the text inside the double brackets. It does this by removing spaces between the words, and automatically capitalizing the first letter of each word following spaces or other punctuation (like ~). Thus Some PmWiki sites (default not) will recognize words written in CamelCase, called a WikiWord, automatically as a link to a page of the same name. Links with different link textThere are three ways to get a different link text: #'''Hide link text'''. Link text within (parentheses) will not be not displayed, so that #'''Change link text'''. You can specify another link text after a vertical brace, as in #'''Show page title instead of page name'''. The use of special characters in the page name is not a problem for PmWiki, but on some servers it may be better to use only plain A-Z letters for the page "name" (which is also a filename), and set the page "title" to the extended or international characters with the (:title PageTitle:) directive within the page. The page title can be shown instead of the page name with the On top of above ways, a suffix can be added to the end of a link, which becomes part of the link text but not of the target page name.
Links with tool tipFrom version 2.2.14 PmWiki can show tooltip titles with the following format: : '''external link''' : @@[[http://pmwiki.org"external tool tip title" | external link ]]@@, eg external link or http://pmwiki.org : '''internal link''': @@[[Links"internal tool tip title" | internal link ]]@@, eg internal link or Links : '''Anchor links''': @@[[#name"anchor tool tip title"|anchor link text]]@@ (since Version 2.2.48), eg anchor link text or #name : '''InterMap link''' : @@[[Wikipedia:Wiki"tool tip title"| InterMap link ]]@@, eg InterMap link or Wikipedia:Wiki Links to nonexistent pagesLinks to nonexistent pages? are displayed specially, to invite others to create the page. See Creating new pages to learn more. Links to pages in other wiki groupsLinks as written above are links between pages of the same group. To create a link to a page in another group, add the name of that other group together with a dot or slash as prefix to the page name. For example, links to
To link to the "default home page" of a group, the name of the page can be omitted:
See Wiki Group to learn more about PmWiki groups. Category linksCategories are a way to organize and find related pages. The idea is that every page that falls into a particular subject area should have a link to a shared page containing links to other pages on that subject. These ''shared pages'' are created in the special group Adding a page to the category User page linksSimilar is So, when the Author field contains "Author": Link shortcuts''' Links to specific locations within a page -- "anchors"To define a location, or bookmark, within a page to which you may jump directly, use the markup * For example, here's a link to the Intermaps section, below. Notes:
* The anchor itself must begin with a letter, '''not a number'''.
* Valid characters for anchor names are letters, digits, dash (-), underscore (_), and the period (.).
* A link to an anchor must have the '''same capitalization as the anchor''' itself.
* Spaces are not allowed in an anchor: " SectionsWhile in HTML the purpose of anchors is mostly for jumping to a position in the text, in PmWiki they serve an internal purpose, too: Each anchor also creates a section, because sections are defined as the part of the page between their start anchor and the next anchor. For more details, see Page Sections. Links to actionsTo link to a specific action for the current page use Examples:
* Links outside the wikiLinks to external sites (URLs)Links to external sites simply begin with a prefix such as 'http:', 'ftp:', etc. Thus If the external link includes (parentheses), escape these using %28 for "(" and %29 for ")" :
The recipe Cookbook:FixURL makes it easy to encode parentheses and other special characters in link addresses. Links with special charactersTo have any special characters, including quotes, spaces, parentheses and pipes in link addresses escape them using Links from the wiki to resources on the same websiteYou can use the Use @@Path:/path/to/resource@@ with a leading slash for links relative to the website document root as in @@www.example.com/path/to/resource@@. You can also define a custom InterMap prefix to a specific path on your website and use it as a shortcut, for example: Pictures: /assets/pictures/$1 Then in a wiki page, use See InterMap for more information. Links to intranet (local) files'''Not all browsers will follow such links''' (some Internet Explorer versions reportedly follow them). You can link to a file system by including the prefix See also Cookbook:DirList. Link characteristicsLinks as ReferencesLinks may also be specified as '''References''', so the target appears as an anonymous ''numeric'' reference rather than a ''textual'' reference. The following markup is provided to produce sequential reference numbering within a PmWiki page: Formatting the link as: Subsequent occurrence of the reference link format on the same page will be incremented automatically as per the following example: Entering IntermapsInter Map links are also supported (see Inter Map). In particular, the Links that open a new browser windowTo have a link open in another window, use * You can also specify that links should open in a new window via the @@%target=_blank%...%%@@ attribute:
Links that are not followed by robotsPrefix a link with %rel=nofollow% to advise robots and link checkers not to follow it. Links and CSS classesPmWiki automatically gives classes to several types of links. Among other things, this enables you to format each type differently. Note: This may be an incomplete list. :.selflink:A link to the current page. Useful in sidebars to show "you are here". :.wikilink:A link to another page within the wiki. :.urllink:A link to a page outside the wiki. Notes'''Note:''' The default behavior of "+" above can be overridden to display the spaced title, rather than simply the title by adding the following to config.php: ->
## [[target |+]] title links
Markup('[[|+', '<[[|',
"/(?>\\[\\[([^|\\]]+))\\|\\s*\\+\\s*]]/e",
"Keep(MakeLink(\$pagename, PSS('$1'),
PageVar(MakePageName(\$pagename,PSS('$1')), '\$Titlespaced')
),'L')");
Q: How do I create a link that will open as a new window? A: Use the
Q: How do I create a link that will open a new window, and configure that new window? A: This requires javascript. See Cookbook:PopupWindow. Q: How do I place a mailing address in a page? A: Use the
See also Cookbook:DeObMail for information on protecting email addresses from spammers. Q: How can I enable links to other protocols, such as nntp:, ssh:, xmpp:, etc? A: See Cookbook:Add Url schemes Q: How do I make a WikiWord link to an external page instead of a WikiPage? A: Use link markup. There are two formats: -> [[http://example.com/ | WikiWord]] [[WikiWord -> http://example.com/]] Q: How do I find all of the pages that link to another page (i.e., backlinks)? A: In the wiki search form, use @@link=Group.Page@@ to find all pages linking to Group.Page. A: Use the -> (:pagelist link=SomePage list=all:) -- show all links to SomePage
(:pagelist link={$FullName} list=all:) -- show all links to the current page
Note that (with a few exceptions) includes, conditionals, pagelists, searchresults, wikitrails, and redirects are not evaluated for Wikilinks, and so any links they put on the page will not be found as backlinks. All other directives and markup, for example links brought to the page by (:pmform:), will be found. Q: What link schemes does PmWiki support? A: See PmWiki:Link schemes Q: How do I open external links in a new window or mark them with an icon? A: See Cookbook:External links Q: How can I use an image as a link? A: Use [[Page| Attach:image.jpg ]] or [[ http://site | http://site/image.jpg ]] See Images#links Q: Why my browser does not follow local file:// links? A: For security reasons, most browsers will only enable file:// links if the page containing the link is itself on the local drive. In other words, most browsers do not allow links to file:// from pages that were fetched using http:// such as in a PmWiki site. See also Cookbook:DirList for a workaround. Q: How links to the first existed page ? for example (:if exists Group1.Page:) [[Group1.Page|Page]] (:elseif exists Group2.Page:) [[Group2.Page|Page]] (:ifend:)(:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:Links, and a talk page: PmWiki:Links-Talk. >><< |
Page last modified on May 24, 2020, at 08:10 AM
