Recent Changes - Search:
<^< BS1852 Resistor Coding | Course index | Measuring Resistance >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ##
Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< BS1852 Resistor Coding | Course Index | Measuring Resistance >^>(:nl:)
>>frame round<< Example 1:
A resistor is marked coded with the legend 6R8K.
What is its value and tolerance? >><<
>>id=example1 class=question margin=10px frame round<< 6.8&#937; ±10% >><<
>>frame round<< Example 2:
A resistor is marked coded with the legend 470RG.
>>id=example2 class=question margin=10px frame round<< 470&#937; ±2% >><<
>>frame round<< Example 3:
A resistor is marked coded with the legend 220KM.
>>id=example3 class=question margin=10px frame round<< 220k&#937; ±20% >><<(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 10:35 AM
