Recent Changes - Search:
<^< Examples: BS1852 Resistor Coding | Course index | Resistor Symbols >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ##
Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Examples: BS1852 Resistor Coding | Course Index | Resistor Symbols >^>(:nl:)
(:video_flv-player Attach:measures_3.flv width=352 height=288 params= startimage= :)
The video shows how an analogue multimeter is used to measure the resistance of a resistor. Before carrying out the measurement it is important to ensure that the meter is correctly zeroed on the ohms range. This involves shorting the test leads together and adjusting the set zero control to obtain full-scale deflection on the meter (the pointer moves to the extreme right-hand of the scale). Once the meter has been zeroed, the test leads are placed on the resistor leads and the scale reading is noted. In this case, the meter resistor has a resistance of 39 ohms. This value agrees with that indicated by the resistor's colour code. (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 01:05 PM
