Recent Changes - Search:
<^< Resistors in Parallel | Course index | Resistance and Temperature >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ##
Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Resistors in Parallel | Course Index | Resistance and Temperature >^>(:nl:)
Objective: To investigate resistors connected in parallel.
Underpinning knowledge: Resistance. Preferred values. Parallel connections.
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: R'_1_' = 1k&#937;, R'_2_' = 2k&#937;, R'_3_' = 3k&#937;.
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Using initial settings verify that 1/R = 1/R'_1_' + 1/R'_2_' + 1/R'_3_'.
(b) Change R'_1_' to 15k&#937;, R'_2_' to 27k&#937; and R'_3_' to 33k&#937;.
(c) Again check that 1/R = 1/R'_1_' + 1/R'_2_' + 1/R'_3_'.
Observations:
Confirm that, in each case, the reciprocal of the effective resistance of the parallel combination of resistors is equal to the sum of the reciprocals of the individual resistance values.
Further work:
Using only preferred value resistors in the E12 series, suggest how you could use a parallel combination of three fixed resistors to obtain the following values of resistance: 333&#937;, 5&#937;, and 3.75&#937;. Check your answers using your simulation software.
(:nl:)(:table style="clear:both":)
Page last modified on August 30, 2011, at 09:04 AM
