Recent Changes - Search:
<^< Examples: Resistance and Temperature | Course index | Negative Temperature Coefficient >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ##
Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Examples: Resistance and Temperature | Course Index | Negative Temperature Coefficient >^>(:nl:)
(:video_flv-player Attach:temcoef_3.flv width=352 height=288 params= startimage= :)
Where the resistance of the material increases with temperature, it is said to exhibit a positive temperature coefficient (PTC). Metals like copper have a positive temperature coefficient.
The video clip shows how the resistance of an PTC resistor increases as the surrounding temperature increases. We are using a candle as a simple heat source. The meter reading moves towards the left hand end of the scale when the thermistor gets hot. Note that, on simple analogue multimeters, zero resistance coincides with full-scale deflection. In other words, if the pointer moves to the left the resistance is increasing whereas if it moves to the right the resistance is decreasing. (:nl:)(:table style="clear:both":)
Page last modified on July 19, 2011, at 03:12 PM
