Recent Changes - Search:
<^< Resistor Construction | Course index | Worksheet: Resistors in Series >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ##
Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Resistors in Series
<^< Resistor Construction | Course Index | Worksheet: Resistors in Series >^>(:nl:)
When two resistors are connected in series, the same current flows in each of them and the effective resistance of the circuit will always be greater than any one of the two resistors taken alone. The effective resistance of a circuit with two resistors (R'_1_' and R'_2_') connected in series is simply the sum of the two resistance values. Thus the effective resistance, R, of the circuit will be given by:
R = R'_1_' + R'_2_'
Similarly, where three resistors (R'_1_', R'_2_', and R'_3_') are connected in series, the effective resistance of the combined circuit will be given by:
R = R'_1_' + R'_2_' + R'_3_' (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 10:09 AM
