Recent Changes - Search:
<^< Resistance and Temperature | Course index | Positive Temperature Coefficient >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ##
Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Resistance and Temperature | Course Index | Positive Temperature Coefficient >^>(:nl:)
>>frame round<<Example 1:
A resistor has a temperature coefficient of 0.002/°C.
If the resistor has a resistance of 2.2k&#937; at 0°C, determine its resistance at 60°C. >><<
>>id=example1 class=question margin=10px frame round<< Now R'_t_' = R'_0_'(1 + &#945;t) thus R'_t_' = 2.2k&#937; x (1 + (0.002 x 60))
Hence R'_60_' = 2.2 x (1 + 0.12) = 2.2 x 1.12 = 2.464k&#937; >><<
>>frame round<< Example 2:
A resistor has a temperature coefficient of 0.0008/°C.
If the resistor has a resistance of 470&#937; as 20°C, what will its resistance be at 70°C? >><<
>>id=example2 class=question margin=10px frame round<< First we must find the resistance at 0°C. Re-arranging the formula for R'_t_' gives:
Now:
R'_t_' = R'_0_'(1 + &#945;t) thus R'_70_' = 470 x (1 + (0.0008 x 70))
Hence: R'_70_' = 470 x (1 + 0.056) = 470 x 1.056 = 496.3&#937;
>>frame round<< Example 3:
A resistor has a resistance of 20&#937; at 0°C and 22&#937; at 100°C.
Determine the temperature coefficient of resistance. >><<
>>id=example3 class=question margin=10px frame round<< First we need to make a the subject of the formula.
R'_t_' = R'_0_'(1 + &#945;t):
Now: 1 + &#945;t =
thus: &#945;t = - 1
Hence: &#945; = = 0.001&#937;/&#937;/°C >><<(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 09:33 AM
