Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors ## Resistor Specifications ## Examples: Resistor Specifications ## Preferred Values: Resistors ## Resistor Colour Code ## Examples: Resistor Colour Code Test ## BS1852 Resistor Coding ## Examples: BS1852 Resistor Coding ## Measuring Resistance ## Resistor Symbols ## Resistor Construction ## Resistors in Series ## Worksheet: Resistors in Series ## Resistors in Parallel ## Worksheet: Resistors in Parallel ## Resistance and Temperature ## Examples: Resistance and Temperature ## Positive Temperature Coefficient ## Negative Temperature Coefficient ## Thermistors ## Light Dependent Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Examples: Resistor Specifications<^< Resistor Specifications | Course Index | Preferred Values: Resistors >^>(:nl:) >>frame round<< Example 1: A resistor has a marked value of 470Ω. Determine the tolerance of the resistor if it has a measured value of 455Ω >><<
>>id=example1 class=question margin=10px frame round<< The difference between the marked and measured values of resistance (the error) is (470Ω - 455Ω) = 15Ω. The tolerance is given by: Tolerance = error / marked value x 100% The tolerance is thus 15/470 x 100 = 3.2% >><< >>frame round<< Example 2: A 12V power supply is to be tested with a 12Ω load resistor. If the resistor has a tolerance of 10% determine: (a) the nominal current taken from the supply (b) the maximum and minimum values of supply current at either end of the tolerance range for the resistor. >><<
>>id=example2 class=question margin=10px frame round<< (a)If a resistor of exactly 12Ω is used the current will be: I = V/R = 12V/12Ω = 1A (b) The lowest value of resistance would be (12Ω - 1.2Ω) = 10.8Ω. In which case the current would be: I = V/R = 12V/10.8Ω = 1.11A At the other extreme, the highest value of resistance would be: (12Ω + 1.2Ω) = 13.2Ω In this case the current would be: I = V/R = 12V/13.2Ω = 0.91A >><<(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 09:33 AM
