(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:)
(:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :)
* Print
(:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:)
* %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]]
(:ifend:) :)
* Login
<^< Preferred Values: Resistors | Course Index | Examples: Resistor Colour Code Test >^>(:nl:)
Carbon and metal oxide resistors are normally marked with colour codes which indicate their value and tolerance. Two methods of colour coding are in common use, one involves four coloured bands whilst the other uses five coloured bands.
'''4 band resistors'''
'''5 band resistors'''
| (:nl:)(:table style="clear:both":)
<^< Preferred Values: Resistors | Course index | Examples: Resistor Colour Code Test >^>
