Recent Changes - Search:
<^< Outputting Data | Course index | Memory >^>
About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs ## Getting Data into a PICmicro ## Outputting Data ##
Current Limits * Memory * Programming * 16F1937 Architecture
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Current Limits
<^< Outputting Data | Course Index | Memory >^>(:nl:)
At some stage you will become interested in the specification of each of the pins of the PICmicro when they are used as digital inputs, analogue inputs, or as digital outputs. It is quite important to be aware of the limitations of the device when used for switching output devices. You should be aware of these limitations at all times. Exceeding these values even for a short time may cause permanent damage to the PICmicro.
Maximum current sunk/sourced by any I/O pin25mA
Maximum current sunk by all ports200mA
Maximum current sourced by all ports140mA
Maximum current out of VSS (Gnd) pin95mA
Maximum current into VDD (5V) pin70mA
Fortunately the E-blocks you will use on this course all have current limiting resistors which will protect your PICmicro device. When using the prototype or patch board you will have no such protection and care must be taken not to damage your device. (:nl:)(:table style="clear:both":)
Page last modified on January 30, 2012, at 02:40 PM
