Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
DebugVariables(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) < Basic Variables | Variables | Edit Variables > : :?action='''ruleset''': displays a list of all markups in 4 columns:
** column 1 = markup-name (1. parameter of markup() )
** column 2 = when will rule apply (2. parameter of markup() )
** column 3 = PmWiki's internal sort key (derived from #2)
** column 4 = Debug backtrace information for potentially incompatible rules (filename, line number, pattern)
->(see Custom Markup Using the Markup() function for custom wiki syntax; migration to PHP 5.5 ).
->To see more than what :?action='''phpinfo''': displays the output of phpinfo() and exits. No page will be processed ** doesn't make use of PmWiki's authorization mechanisms. :?action='''diag''': displays a dump of all global vars and exits. No page will be processed ** doesn't make use of PmWiki's authorization mechanisms. >><< : : : : :The timings can be displayed by adding : :Valid values are:
: :See Stopwatch for more details. See also: * scripts/refcount.php is useful for debugging ----
>>faq<<
Q:Is it possible for someone with admin priviledges to always have access to debugging tools, without letting everyone else access them?
A:You can easily & automatically allow debugging for anyone with admin priviledges (meanwhile leaving it off for everyone else) by including this line in config.php - ''just be sure that 1) -->@@if (CondAuth( >><< (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) < Basic Variables | Variables | Edit Variables > <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:DebugVariables, and a talk page: PmWiki:DebugVariables-Talk. >><< |
Page last modified on July 14, 2018, at 11:52 AM
