Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
CustomMarkup(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) administrators (intermediate)
(:nl:)(:Summary: Using the Markup() function for custom wiki syntax; migration to PHP 5.5:)
(:Audience: administrators (intermediate) :) PmWiki's markup translation engine is handled by a set of rules; each rule searches for a specific pattern in the markup text and replaces it with some replacement text. Internally, this is accomplished by using PHP's "preg_replace" function. IntroductionRules are added to the translation engine via PmWiki's Markup() or function, which look like -> Markup($name, $when, $pattern, $replace); # if no evaluation is needed, or if PHP < 5.5 Markup($name, $when, $pattern, $replace_function); # if evaluation is needed <:vspace> # DEPRECATED, will not work as of PHP 7.2 Markup_e($name, $when, $pattern, $replace); # if evaluation is needed and 5.5<=PHP<=7.1 * For example, here's the code that creates the rule for Basically this statement says to create a rule called "em" to be performed with the other "inline" markups, and the rule replaces any text inside two pairs of single quotes with the same text ($1) surrounded by Sequence in which rules are appliedThe first two parameters to Markup() are used to specify the sequence in which rules should be applied. The first parameter provides a name for a rule -- " The second parameter says that this rule is to be done along with the other "inline" markups. PmWiki divides the translation process into a number of phases: _begin start of translation
{$var} Page Text Variables happen here.
fulltext translations to be performed on the full text
split conversion of the full markup text into lines to be processed
directives directive processing
inline inline markups
links conversion of links, url-links, and WikiWords
block block markups
style style handling
_end end of translation
This argument is normally specified as a left-angle bracket ("before") or a right-angle bracket ("after") followed by the name of another rule. Thus, specifying "inline" for the second parameter says that this rule should be applied when the other "inline" rules are being performed. If we want a rule to be performed with the directives -- i.e., before inline rules are processed, we would specify "directives" or "<inline" for the second parameter. {$var} and (:if ...:) conditionalsA significant rule in terms of ordering is "{$var}" which substitutes variables -- if you say "<{$var}" then your markup will be processed before variables are substituted whereas if you say ">{$var}" then your markup will be processed after variables are substituted. This happens before conditional (:if...:) expressions, which is why page text variables are processed even if they are defined inside (:if false:). Markup regular expression definitionThe third parameter is a Perl-compatible regular expression. Basically, it is a slash, a regular expression, another slash, and a set of optional modifiers. The example uses the pattern string Replacement textThe fourth parameter is the replacement text that should be inserted instead of the marked-up wikitext. You can use In the example, we have Here's a rule for -> and for a -> Okay, now how about the rule for -> This creates a rule called "strong", and the second parameter "<em" says to be sure that this rule is processed before the "em" rule we defined above. If we wanted to do something after the "em" rule, we would use ">em" instead. Thus, it's possible to add rules at any point in PmWiki's markup translation process in an extensible manner. (In fact, the "inline", "block", "directives", etc., phases above are just placeholder rules used to provide an overall sequence for other rules. Thus one can use "<inline" to specify rules that should be handled before any other inline rules.) If you want to disable available markup just call e.g.: -> PmWiki's default markup rules are defined in the ''scripts/stdmarkup.php'' file. To see the entire translation table as the program is running, the scripts/diag.php module adds " Other common examplesDefine a custom markup to produce a specific HTML or Javascript sequenceSuppose an admin wants to have a simple " ->
Markup('example', 'directives',
'/\\(:example:\\)/',
Keep("<div class='example'><p>Here is a
<a target='_blank' href='http://www.example.com'>link</a> to
<em>example.com</em></p></div>") );
* The first argument is a unique name for the markup ("example"). * The second argument says to perform this markup along with other directives. * The third argument is the pattern to look for "(:example:)". * The fourth argument is the HTML that "(:example:)" is to be replaced with. We use the Keep() function here to prevent the output from being further processed by PmWiki's markup rule -- in the above example, we don't want the http://www.example.com url to be again converted to a link. Define a markup to call a custom function that returns content-> The /e modifier has been deprecated and should not be used in ongoing development. See below for more details. For older PHP versions (< 7.2) an 'e' option on the ->
Markup('random', 'directives',
'/\\(:random:\\)/',
"MyRandomFunction");
function MyRandomFunction() {
return rand(1, 100);
This calls the PHP built-in rand() function and substitutes the directive with the result. Any function can be called, including functions defined in a local customization file or in Cookbook recipes. Arguments can also be passed by using regular expression capturing parentheses, thus ->
Markup('randomargs', 'directives',
'/\\(:random (\\d+) (\\d+):\\)/',
function MyRandomFunction($m) {
return rand($m[1], $m[2]);
will cause the markup -> Note: the /e modifier in regular expressions is deprecated since PHP version 5.5, and removed since PHP version 7. The reason for this is, that malicious authors could pass strings that could cause arbitrary and undesirable PHP functions to be executed. For a PmWiki function to help with parsing arbitrary sequences of arguments and key=value pairs, see Cookbook:ParseArgs. Migration to PHP 5.5 and @@Markup_e()@@Since PHP version 5.5, the @@/e@@ evaluation modifier is deprecated and some hosting providers don't allow its use. Recent versions of the PmWiki core (2.2.58 and newer) allow new ways to define markup rules without being dependent on the @@/e@@ eval modifier. The historical ways to define markup rules are not removed and work, but may be incompatible with PHP 5.5 installations. ''Note: whether your replacement pattern needs evaluation or not, you must use @@Markup()@@ and not @@Markup_e()@@.'' The latter is deprecated and should no longer be used for new recipes and customizations, and old recipes using @@Markup_e@@ should be upgraded to the new format. The examples below all require PmWiki 2.2.58 (2013-12-25) or newer but the latest version is recommended. >>frame<< THE SHORT ANSWER: If your markup regular expression (the 3rd argument) contains an "e" after the closing slash (i.e., @@/regex/e@@ or @@/regex/se@@ or etc) AND your 4th argument is entirely surrounded with double-quotes then you may be able to get away with simply following these simple steps: # Delete the "e" from after the closing slash in the 3rd argument
# Create a new replacement function with $m as argument.
# In your function, the previous occurrences of '$1', '$2', etc. are now found as $m[1], $m[2], etc. You should no longer call @@PSS()@@.
# In your function, call @@extract($GLOBALS['MarkupToHTML']);@@ in order to get the current In some cases this will not suffice - it depends on how quoting was done - but in many cases following these simple steps will result in PHP 5.5+ compatibility. If you try those steps and are still having problems then continue to read below for a deeper understanding. >><< The following is acceptable for PHP 5.5+ (compatible with PmWiki 2.2.58+, will also work in PHP 5.4 and older) * @@Markup($name, $when, $pattern, $replace)@@; ** @@$pattern@@ can no longer have an "@@/e@@" modifier ** @@$replace@@ can be a function name (callback) which will be called with the array of matches as argument ** instead of a string, the fourth parameter can be a definition of an anonymous function (note you can use anon functions this way since PHP 5.3.0+). * @@Markup_e($name, $when, $pattern, $replace)@@; DEPRECATED, should no longer be used Examples: * For PHP 5.4 and older, this was acceptable:
'/\\(:random (\\d+) (\\d+):\\)/e',
"rand('$1', '$2')"
* For PHP 5.5 and newer, $replace is callback, we call Markup():
"MyRandom"
function MyRandom($m) { # $m = matches
return rand($m[1], $m[2]); # note "return" is used, unlike before
This will also work in PHP 5.4 and older
Other example: * PHP 5.4 or older:
Markup('Maxi:','<links',
"/\\b([Mm]axi:)([^\\s\"\\|\\[\\]]+)(\"([^\"]*)\")?/e",
"Keep(LinkMaxi(\$pagename,'$1','$2','$4','$1$2'),'L')"
* PHP 5.5 or newer, PmWiki 2.2.58+, $replace is a function name:
"/\\b([Mm]axi:)([^\\s\"\\|\\[\\]]+)(\"([^\"]*)\")?/",
"LinkMaxi"
function LinkMaxi($m) {
extract($GLOBALS['MarkupToHTML']); # to get $pagename
# do stuff with $m[1], $m[2], etc.
return Keep($out, 'L');
* $replace can also be a callback function, we call Markup():
"CallbackMaxi"
function CallbackMaxi($m) {
extract($GLOBALS["MarkupToHTML"]); # to get $pagename
return Keep(LinkMaxi($pagename,$m[1],$m[2],$m[4],$m[1].$m[2]),'L');
The above may seem complicated, but it is actually simpler to use your own callback function: >>frame<<
Markup('mykey', 'directives',
'/\\(:mydirective (.*?) (.*?):\\)/i',
'MyFunction'
function MyFunction($m) {
<:vspace>
# ... do stuff with $m (the matches), drop PSS() ...
<:vspace>
return $out; # or return Keep($html);
If you have any questions about the new way to define custom markup, you can ask us at the talk page or on the mailing lists. FAQ>>faq<<
Q: How can I embed JavaScript into a page's output?
A: There are several ways to do this. The Cookbook:JavaScript recipe describes a simple means for embedding static JavaScript into web pages using custom markup. For editing JavaScript directly in wiki pages (which can pose various security risks), see the JavaScript-Editable recipe. For JavaScript that is to appear in headers or footers of pages, the skin template can be modified directly, or <script> statements can be inserted using the Q: How would I create a markup (''(:nodiscussion:)'') that will set a page variable (''{$HideDiscussion}'') which can be used by ''(:if enabled HideDiscussion:)'' in .PageActions? A: Add the following section of code to your config.php ->
SDV($HideDiscussion, 0); #define var name
Markup('hideDiscussion', '<{$var}',
'/\\(:nodiscussion:\\)/', 'setHideDiscussion');
function setHideDiscussion() {
global $HideDiscussion;
$HideDiscussion = true;
This will enable the @@(:if enabled HideDiscussion:)@@ markup to be used. If you want to print the current value of {$HideDiscussion} (for testing purposes) on the page, you'll also need to add the line: Q: It appears that (.*?) does not match newlines in these functions, making the above example inoperable if the text to be wrappen in <em> contains new lines. A: If you include the "s" modifier on the regular expression then the dot (.) will match newlines. Thus your regular expression will be "/STUFF(.*?)/s". That s at the very end is what you are looking for. If you start getting into multi-line regexes you may be forced to look at the m option as well - let's anchors (^ and $) match not begin/end of strings but also begin/end of lines (i.e., right before/after a newline). Also make sure your markup is executed during the fulltext phase. Q: How can the text returned by my markup function be re-processed by the markup engine? A: If the result of your markup contains more markup that should be processed, you have two options. First is to select a "when" argument that is processed earlier than the markup in your result. For example, if your markup may return [[links]], your "when" argument could be @@"<links"@@ and your markup will be processed before the links markup. The second option is to call the PRR() function in your markup definition or inside your markup function. In this case, after your markup is processed, PmWiki will restart all markups from the beginning. Q: How do I get started writing recipes and creating my own custom markup? A: (alternate) Introduction to custom markup for Beginners Q: How do I make a rule that runs once at the end of all other rule processing? A: Use this statement instead of the usual @@Markup()@@ call: -->@@$MarkupFrameBase['posteval']['myfooter'] = "\$out = onetimerule(\$out);";@@(:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:CustomMarkup, and a talk page: PmWiki:CustomMarkup-Talk. >><< |
Page last modified on August 30, 2019, at 12:03 PM
