Recent Changes - Search:
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
PageTextVariables
(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :)
(:nl:)(:Summary:Page variables automatically made available through natural or explicit page markup:)
Page text variables are string variables created in the wiki text of a page, and can be automatically made available for inclusion in other pages. In the default installation, PageTextVariables can only have a name containing basic Latin/Roman (ASCII) letters, digits, dash and underscore. This is a limitation for international wikis (experimental recipe for international PTV : Cookbook:InternationalPTVs).
Defining Page Text Variables
There are three ways to define automated Page Text Variables (more patterns can be defined if needed) :
* use a definition list - the normal pmwiki markup for a definition list will create a page text variable
Example definition list:
:Name: Crisses
"{$:Name}"
:Name: Crisses "Crisses"
->This creates a new variable that can be accessed by {$:Name} (becomes: "Crisses") in the page.
* use a simple colon delimiter in normal text
Example colon delimited:
Address: 1313 Mockingbird Lane
<:vspace>
"{$:Address}"
"1313 Mockingbird Lane"
->This creates the {$:Address} variable (variable markup becomes: "1313 Mockingbird Lane") in the page.
* hidden directive form - PmWiki markup that doesn't render on the page, but defines the variable
Example directive:
(:Country: Transylvania :)
"{$:Country}"
(:Country: Transylvania :) "Transylvania "
->This creates the {$:Country} variable (variable markup becomes: "Transylvania ") in the page.
Default values for unset or empty Page Text Variables
If a page text variable is not defined in a page, or if the current visitor doesn't have read permissions for the page containing the variable definition, then the markup to access the variable like {$:Country} will return an empty string.
An administrator can define default values for such cases (PmWiki 2.2.121+). The following arrays can be defined in local/config.php:
  $DefaultUnsetPageTextVars = array(
    'SpecificVariable' => 'SpecificVariable is unset',
    '*PartialMatch*' => 'some value',
    '*' => '(unset)',
  $DefaultEmptyPageTextVars = array(
    'SpecificVariable' => 'SpecificVariable is set, but empty',
    '*' => '(empty)',
In the above examples, {$:SpecificVariable} or {OtherPage$:SpecificVariable} will output the value defined: * in $DefaultUnsetPageTextVars if the variable is not defined in the page text, or if the user doesn't have read permissions for OtherPage * in $DefaultEmptyPageTextVars if the user has read permissions, and the variable is defined but empty, for example (:SpecificVariable::).
The patterns are processed in order, and the first matching pattern assigns the value to the variable. The asterisk * matches any string, in the above examples an undefined variable that doesn't match 'SpecificVariable' or '*PartialMatch*' will output '(unset)'.
Usage
Usage on the same page
On the same page you can resolve page text variables through the {$:Var} format (shown above).
Usage in headers and footers: special references
If you want a GroupHeader, GroupFooter, SideBar, etc to call on page text variable in the main page, you need to include special reference information. To explicitly reference the page text variable from the page being displayed add an asterisk to the page text variable's markup: {*$:Address} on the GroupFooter or GroupHeader page.
Example
{*$:Mountain} \\
{*$Namespaced}
Mt Ruapehu
Page Text Variables
To include a page text variable ''from'' a header or footer see usage from other pages below. -< Special references also apply to page variables and page list templates.
Usage from other pages
If you want to pull the data from another page, use the {Group/PageName$:Var} format.
Example:
Suburb: Khandallah
(:Lake:Taupo:)
:Mountain:Mt Ruapehu
<:vspace>
->"{PmWiki/PageTextVariables$:Suburb}"
->"{{$FullName}$:Lake}"
->"{PmWiki/PageTextVariables$:Mountain}"
Suburb: Khandallah (:Lake:Taupo:) :Mountain:Mt Ruapehu
->"Khandallah" ->"Taupo" ->"Mt Ruapehu"
Usage from included pages
Page text variables are never included from their source page. See Usage from other pages above to refer to a page text variable on another page.
Usage with pagelists
Page lists can also access the page text variables:
Example:
(:pagelist group=PmWiki order=$:Summary count=6 fmt=#singleline:)
And to create pagelist formats (such as those documented at Site.Page List Templates, Page Lists, Page List Templates, Page Variables. Store custom pagelists at Site.Local Templates?).
Page lists can also use page text variables to select pages :
Example:
(:pagelist group=PmWiki $:City=Paris count=8 fmt=#singleline order=-name:)
->lists pages having '$:City' set to 'Paris'.
Example: multiple selections with spaces
(:pagelist group=PmWiki $:City="Addis Ababa,Paris" order=-$:Version count=8 fmt=#singleline:)
->'quotes' must surround ''all'' the selections.
* When using page text variables for selection or ordering, don't put the curly braces around the variable name. The curly forms do a replacement before the pagelist command is evaluated. * Link markup within the contents of a hidden page text variable directive (as opposed to other ways of specifying PTVs) will not be cached as a link on the page and thus won't be seen by pagelist's link= option. If you want the link to be found by link=, you need to specify the PTV using non-directive markup, or else put the link on the page even if it's hidden within a false conditional: (:Linkme: [[PageToLink]]:) (:if false:){$:Linkme}(:ifend:)
The page text variable value is always the text that is written in the page. It is only evaluated when the variable is printed/output to HTML. To sort by a page text variable variable, all values in all pages are the not-yet-evaluated text strings, and the pagelist order function does what it can with them. It does not process/evaluate the text at this point.
E.g. With a page name in to format "yyyyMonth" it is simpler to use a @@PageVariable@@ calculated in @@config.php@@, not a @@PageTextVariable@@: -> $FmtPV['$NameToYearMonth'] = 'strftime("%Y%m", strtotime($name))'; Then use (:pagelist order=$NameToYearMonth:)
An alternative is writing in the wiki page: -> (:MonthNum:07:) as the markup expression that follows won't work: -> (:MonthNum:{(ftime fmt=%m when="{$Namespaced}")}:)
Testing if set or not set within a pagelist
'''=-'''PTV is set (is not empty), eg (:pagelist $:Var=- :)
'''=-?*'''PTV is not set (is empty), ie not one character followed by 0 or more characters, eg. (:pagelist $:Var=-?* :)
'''=*'''display ''all'' pages, regardless of the page text variable (slow)
'''=-*'''display ''no'' pages, regardless of the page text variable (slow)
Tip : (:if ! equal "{$:PTV}" "":) will test if PTV is empty/unset or not.
Example: Pages without a summary
(:pagelist group=PmWiki $:Summary=-?* count=6  fmt=#singleline:)
Use page text variable in a template
Display pages by Audience page text variable.
Example:
>>comment<<
[[#byaudience]]
(:if ! equal '{=$:Audience}' '{<$:Audience}':)
-<'''{=$:Audience}''':
(:ifend:)
[[{=$Name}]]
[[#byaudienceend]]
(:pagelist group=PmWiki count=10 fmt=#byaudience order=-$:Audience:)
>>comment<< -<'''{=$:Audience}''': {=$Name}? >><<
-<'''visitors (intermediate) ''': AccessKeys WebFeeds -<'''authors, admins (intermediate) ''': PageLists -<'''authors, admins (advanced) ''': ConditionalMarkup -<'''authors (intermediate) ''': Categories IncludeOtherPages GroupHeaders TableDirectives Uploads PageVariables
Use page text variables in conditional markup
Page text variables will be assigned/evaluated '''before''' any conditional markup is evaluated. This effectively means that you cannot declare a PTV within an if...else condition; and also that a PTV will have a value even if it is set within a (:if false:)....(:if:) condition.
Usage - from within code (developers only)
The standard @@PageVar($pagename,$varname)@@ function can return page text variables, but remember to include the dollar and colon like this:
->@@$var=PageVar($pagename,'$:City')@@
It works by caching all page (text) variables it finds in a page (in @@$PCache@@) and returns the one requested.(:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :)
<<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:PageTextVariables, and a talk page: PmWiki:PageTextVariables-Talk. >><<
Page last modified on October 30, 2019, at 09:13 AM
