Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
PageListTemplates(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) Default page list templatesPmWiki's default templates for page lists are in Site.PageListTemplates, which is replaced during upgrades. These default templates can be supplemented or overridden with custom templates stored in other locations. PmWiki's default configuration looks for templates in the following locations in the following order:
# the page name specified as part of the template name
# the current page body
# Site.LocalTemplates?,
# Site.PageListTemplates
If the pagelist is defined in a sidebar, group header or footer, etc, the page name must be specified as part of the template name.
Administrators can change those locations by using the If the template is on the current page, the current page must be saved for changes involving the template to show up ''(preview alone will not work)''. Custom page list templatesCustom templates are used in the same way as default templates: by referencing the desired format with the @@fmt=#''anchor''@@ option.
There are several ways to indicate which template to use:
* See Cookbook:PagelistTemplateSamples for examples of custom pagelist formats. Creating page list templatesA pagelist template contains standard pmwiki markup. When creating pagelist output, pmwiki iterates over each page returned from the pagelist and will include the pagelist template markup once for every page in the list. Special referencesDuring the page list iteration pmwiki sets 3 special page references: '''=''', '''<''' and '''>'''. These special page references are updated on each pagelist iteration and can be used with the page variables syntax, such as ''{=$variable}'', to define a pagelist template which will format the pagelist output. The meaning of the special references are:
The > and < references are most useful to help structure pagelist output before and after the actual pagelist. Some common tests used to structure pagelist output are:
Page list template special markupPagelist templates may have special sections
* There's also a
* to allow a template to specify default options, * to signify the repeated part, and * whose content will appear if no page was found (from version 2.2.5). These allow Pagelist templates to be easily separated into "sections" that are included or not included in the output based on a variety of conditions. These are intended to be improved versions of the (:if ...:) conditions that have traditionally been used to control pagelist output (however, the (:if:) conditions still work as before). First, Each, Last, NoneThe simplest versions of the directives are: -> (:template first:) # markup to display only for first page in list (:template ! first:) # markup to display for every page in list but the first (:template each:) # markup to display for each page in list (:template last:) # markup to display only on last page in list (:template ! last:) # markup to display for every page in list but the last (:template none:) # markup to display only if no pages were found So, a pagelist template can specify: -> (:template first:)
Pages in the list:
(:template each:)
* [[{=$FullName}]] [-{=$:Summary}-]
(:template last:)
Displayed {$$PageCount} pages.
In addition, the "first" and "last" options can have control break arguments that identify markup to be displayed on the first or last page within a particular control section. For example, to specify markup to be displayed upon reaching the first or last page of a group, one can use -> (:template first {=$Group}:)
(:template last {=$Group}:)
Thus, instead of writing control breaks using directives, as in -> (:if ! equal {<$Group} {=$Group}:)
Group: {=$Group}
(:ifend:)
* [[{=$FullName}]]
one can now write -> (:template first {=$Group}:)
Group: {=$Group}
(:template each:)
* [[{=$FullName}]]
Page text variables and page variables can also be used, for example -> (:template default $:Maintainer=- order=$:Maintainer,name:)
(:template first {=$:Maintainer}:)
Default optionsIn addition, a template may specify default options to be used in the pagelist command. For example, a pagelist template to display a list of pages by their titles (and sorted by title) might use: -> [[#bytitle]]
(:template defaults order=title:)
* [[{=$FullName}|+]]
[[#bytitleend]]
Then an author could write (:pagelist fmt=#bytitle:) and the pages would automatically be sorted by title without having to specify an additional "order=title" option to the (:pagelist:) directive. To specify multiple parameters to an option enclose the parameters in double quotes, eg to sort by a page text variable and then the page name
-> Examples:(:template defaults ... :) : default options for pagelists using this template :(:template each:) : markup for each page in the pagelist :(:template first:) : markup output only for the first page in the pagelist :(:template last:) : markup output only for the last page in the pagelist :(:template first {=$Group}:) : markup output only for a page where the value of {=$Group} has just changed :(:template last {=$Group}:) : markup output only for a page where the value of {=$Group} will change with the next page So, we have: -> [[#template]]
(:template defaults order=name:)
(:template first:)
Pages ordered by group
<:vspace>
Pages in group [[{=$Group}/]]
(:template each:)
* [[{=$FullName}]]
{=$Group} contains {$$GroupPageCount} pages.
(:template last:)
{$$PageCount} pages total.
[[#templateend]]
Page list template additional page variablesAdditional Page Variables that are only available during pagelist are: ->
{$$PageCount} The current page count of this iteration
{$$GroupCount} The current group count of this iteration
{$$GroupPageCount} The current page count within the current group of this iteration
{$$EachCount} The current page count within the current loop
->@@{$$''option''} The argument option values from @@(:pagelist:)
Use of {$$''option''}: For example {$$trail} returns the page name entered in the trail= option of the pagelist directive. You can make up custom "options" with no other purpose than being displayed in the pagelist. RedirectTo enable searches that return only one page to automatically redirect to that page add the following to a pagelist template where the "jump to a page" functionality is desired: -> (:template last:)
(:if equal {$$PageCount} 1:)(:redirect {=$FullName}:)(:ifend:)
Closure of markupAny open tables, divs, or other structures inside of (:pagelist:) are, by default, automatically closed at the end of the pagelist command. In other words, (:pagelist:) acts like its own complete page, as opposed to generating markup that is then inserted into the enclosing page. For example a table generated by the (:cell:) directive in the first (:pagelist:) command is automatically closed at the end of the pagelist. The (:cell:) in the second (:pagelist:) command then starts a new table. Note that the (:table:) directive doesn't actually start a new table, it's the (:cell:) or (:cellnr:) directive that does it. All that the (:table:) directive does is set attributes for any tables that follow. UsageIt is advisable to not modify the page Site.PageListTemplates directly so that you will still benefit from upgrades. Instead, modify your Site.LocalTemplates? page (which is not part of the PmWiki distribution). Cookbook:PagelistTemplateSamples has many examples of custom pagelist formats. Other recipesIn addition, the Cookbook has other recipes for special |
Page last modified on November 19, 2019, at 11:24 AM
