Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
PagelistVariables(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) < Other Variables | Variables | Path Variables > : : : : # Limit all searches to Main group
$SearchPatterns['default'][] = '/^Main\\./';
# Exclude the Main group from search results
$SearchPatterns['default'][] = '!^Main\\.!';
# Exclude RecentChanges pages from search results
$SearchPatterns['default'][] = '!\\.(All)?RecentChanges$!';
# Prevent a page from listing itself in (:pagelist:) or (:searchresults:)
$SearchPatterns['default'][] = FmtPageName('!^$FullName$!', $pagename);
: : : : : # Enable pagelist caching in work.d/.pagelistcache $PageListCacheDir = 'work.d/.pagelistcache'; : # Simple use of page search form in the default group $PageSearchForm = '$DefaultGroup.Search';--> # Use Search page in current group if it exists, otherwise use Site.Search
$PageSearchForm = array('$Group.Search', '[=$[$SiteGroup/Search]=]');
: --> # PMWiki default setup
global $FPLTemplatePageFmt;
$FPLTemplatePageFmt = array(
'{$FullName}',
'{$SiteGroup}.LocalTemplates',
'{$SiteGroup}.PageListTemplates');
-> It can be customized to look in other pages. --> # Search a Group.Templates page as well as the Site templates
'{$Group}.Templates',
-> Or declare defaults for the template array: --> # Search a Group.Templates page as well as the Site templates
SDV($FPLTemplatePageFmt, array('{$FullName}',
'{$SiteGroup}.LocalTemplates', '{$SiteGroup}.PageListTemplates')
: < Other Variables | Variables | Path Variables > <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:PagelistVariables, and a talk page: PmWiki:PagelistVariables-Talk. >><< |
Page last modified on January 30, 2020, at 06:19 AM
