Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Table directives(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) authors (intermediate)
(:nl:)(:Summary:Directives for table processing:)(:Audience: authors (intermediate) :)
See Tables for the "simple table" markup. Here you can find the markup for advanced/structural tables. There are six directives for table processing. All must be at the beginning of a line to have any effect. @@(:table [attr...]:)@@Generates a new HTML <table> tag with the attributes provided in ''attr...''. Closes the previous table, if any. Valid attributes and values are: * border ''(a positive integer)'' * bordercolor ''(a color name or hex number; doesn't display in all browsers)'' * cellspacing ''(a positive integer indicating the space between cells)'' * cellpadding ''(a positive integer indicating the interior border of a cell)'' * width ''(a positive integer or percent)'' * bgcolor ''(a color name or hex number)'' * align ''(left, center or right)'' * summary ''(does not display; used primarily to help visually disabled people navigate)'' * style ''(CSS rules for the table)'' * class ''(CSS class name for the table)'' @@(:cellnr [attr...]:), (:cell [attr...]:), (:headnr [attr...]:), (:head [attr...]:) @@* The @@ (:head:) @@ directive opens a new "header cell" of the table (creates @@ <th> @@ tag in HTML). * The @@ (:cell:) @@ directive opens a new "regular cell" of the table (creates @@ <td> @@ tag in HTML). * The directives @@ (:headnr:) @@ and @@ (:cellnr:) @@ open a new cell on a new row in the table. These directives close any previous cell and/or row. Note, the @@ (:head:) @@ and @@ (:headnr:) @@ directives exist from PmWiki version 2.2.11 or newer. Valid attributes and values are: * align ''(left, center or right)'' * valign ''(top, middle or bottom)'' * ''default is "top", see note below'' * colspan ''(a positive integer)'' * rowspan ''(a positive integer)'' * bgcolor ''(a color name or hex number)'' * width ''(a positive integer or percent)'' * class ''(a CSS class of the cell)'' * style ''(custom CSS styles of the cell)'' @@ (:tableend:) @@Closes the previous table cell and closes off any table. Generates </th>, </td>, </tr>, and </table> tags as needed. * valign attributeIf not already set, PmWiki will automatically include the attribute valign='top' with all See NotesFor the table, cell, and cellnr tags the author can specify any attributes that would be valid in the HTML <table> or <td> tags. Thus you can specify rowspan, colspan, etc. arguments to build arbitrary tables. However, it's not possible to nest a Many are likely to ask why we didn't just use the standard HTML table markup (<table>, <tr>, <td>, <th>) instead of creating a new markup, and allowing nested tables as a result. There are two answers: first, the HTML table markup is very ugly for naive authors (see PmWiki.Audiences and PmWikiPhilosophy #2), and second, it'd be very easy for authors to create tables that are incorrect HTML and that display incorrectly (or not at all) on some browsers. Even seasoned web professionals sometimes get the table markup wrong, so it's a bit unrealistic to expect the average author to always get it right, or to be able to read arbitrary HTML table markup that someone else has created. -> ''Common comment:'' Surely, the average or naive author would not be writing HTML directly, but using a tool, such as FrontPage, or even MSWord, to generate the HTML. This would be a lot simpler than learning even the simplest PmWiki markups. >><< -> ''Pm's Response:'' And once the HTML has been generated and posted, how is someone else going to edit or modify the table if they don't have the original FrontPage or MSWord file used to create it? Remember that we're talking about ''collaborative'' authoring. The HTML that those packages generate is among the hardest to read and edit of all! It's difficult to write the code needed to make PmWiki understand and fix arbitrary table markup, so PmWiki uses the simplified version above. Still, this version is able to handle most table requirements (with the possible exception of nested tables). And, this is not to say that nested HTML tables are impossible in PmWiki --they just can't be easily created by wiki authors using the default wiki markup. A site administrator can of course create header/footer HTML code and other local customizations that make use of nested tables. ExamplesA table using table directive markup."
In HTML, this is the same as ->
<table border='1' cellpadding='5' cellspacing='0'>
<tr>
<th>a1</th>
<td>b1</td>
<td>c1</td>
<td>d1</td>
</tr>
<tr>
<th>a2</th>
<td>b2</td>
<td>c2</td>
<td> </td>
</tr>
</table>
----- Floating Table with bulleted navigation listWhat if you wanted to create a nice little table like a table of contents in a page like this? In this example, the table is floating right and contains some links in a bulleted list. This is a nice demonstration of how it's possible to build a little table of contents in the page, which might navigate to other pages just within the same wiki group. Note that having a bulleted list ''won't work in a ordinary table'' - it only works inside an table created with table directives such as the example code used here.
Looking at the markup here, notice that we have used a #cccc99 hex color for the table background. Also, the You could take this concept a little further: since you might want each page in the group to contain the same table of contents, you can make ONE table like the above and put it in its own page. Then use an include on any of your pages and bring in the table. The float (align) property will be honored in each page where it's included. FAQQ: Can I define table headers using the table directive markup?
A: Yes, use Q: Is it possible to do nested tables? A: Yes, if you nest simple tables inside advanced tables. See also Cookbook:AdvancedTableDirectives. Q: Is it possible to add background images to tables and table cells? A: Yes, see Cookbook:BackgroundImages. Q: Is it possible to apply styles to the elements of the table, like an ID to the table row, or a class/style to the TD? A: Yes, see $WikiStyleApply. Q: Is it possible to automatically generate columns or rows in tables, i.e. without having to do a lot of counting? A: Yes, this is possible with the Cookbook:CreateColumns recipe - it allows you to specify a certain number of columns, and/or to specify a certain number of items per column. Plus, someone has provided some similar markup on the TableDirectives-Talk page. Q: Is it possible to use table captions in table directives similar to simple tables? Tried <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:TableDirectives, and a talk page: PmWiki:TableDirectives-Talk. >><< |
Page last modified on January 17, 2020, at 08:54 AM
