Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
LocalCustomizations(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) A Wiki Administrator can make a lot of customizations simply by setting variables in the ''/local/config.php'' and defining cascading style sheets in ''/pub/css/local.css'' files. Any group or page can also have its own configuration file and configuration css file. This page describes how customizations work in general, see PmWiki.Documentation Index for specific customizations that are commonly performed at many PmWiki installations, including: * Skins - Change the look and feel of part or all of PmWiki * Internationalizations - Language internationalisation of web pages * Custom Markup - Using the Markup() function for custom wiki syntax; migration to PHP 5.5 * InterMaps - Interwiki links definition and use local/config.phpFrom its inception, PmWiki has been designed so that Wiki Administrators can greatly customize the way PmWiki displays pages and the markup sequences used to generate pages. (This is even mentioned explicitly in PmWiki Philosophy #4 Collaborative Maintenance.) As a result, the core ''pmwiki.php'' script makes extensive use of PmWiki.Variables to determine how markup sequences will be processed and what each individual page will output. The simplest type of customization is merely setting a variable to 1 (or TRUE). Here's an example that enables ?action=diag and ?action=phpinfo actions:
->@@ You can begin a line with a "#" (an octothorpe, a.k.a. a hash symbol or pound sign) to add a comment. Additionally, some built-in PmWiki variables take values other than 1 or 0 (true or false). Here's another example that customizes the wiki's behavior with respect to search engine web robots (see Cookbook:ControllingWebRobots): -> # Remove the default "rel='nofollow'" attribute for external links. $UrlLinkFmt = "<a class='urllink' href='\$LinkUrl' title='\$LinkAlt'>\$LinkText</a>"; The ''scripts/'' subdirectory (below the directory holding the ''pmwiki.php'' script) has many customizations. The PmWiki Cookbook contains many example customizations (recipes) that you can download into the ''cookbook/'' subdirectory, The first few lines of each of these scripts generally contain instructions about how to enable (and use) the feature provided by the script. These customizations are included in your ''config.php'' site configuration. For most scripts this is done by simply adding lines like:
-> Some of the scripts are automatically enabled for you via the ''scripts/stdconfig.php'' script unless you disable it by setting @@ Order of the commands in config.phpThe following order is recommended: * define >>frame hlt php<< If you need to set per-page or per-group variables or addons, it is recommended to add them into files named local/Group.php and local/Group.Page.php. If you must do it from config.php, or if you need to set these variables after the local files are included, use the following at the bottom of config.php: ''' Any direct function call in config.php, like CondAuth(), PageTextVar(), PageVar(), RetrieveAuthPage(), or others, should be done near the end of config.php after the above snippet in bold. Alternatively, you can add those in a custom function or script in the $PostConfig array: # PmWiki will call this function and include this file '''after''' # farmconfig.php, config.php, Group.Page.php and Group.php # but '''before''' scripts/stdconfig.php: function MyFunction1( The $PostConfig functions and scripts will be called ordered by their values, ie above "MyFunction2" (125) will be called after "other-addon.php" (100). This allows recipe authors more control over the precise order of their recipe compared to other recipes (when that is important). >><< ''Note, each part is '''not''' required, but if your wiki needs it, this is the recommended order in config.php.'' Character encoding of config.phpThe encoding used when you save Newer operating systems like GNU/Linux, FreeBSD and Apple generally default to saving text files in Unicode/UTF-8; in Windows the default encoding is ANSI/Windows-1252 which is almost the same as PmWiki's ISO-8859-1. The following ''free/libre software'' text editors can edit and save a file in different encodings: * Cross-platform: Kate (for KDE), Geany, Arachnophilia, SciTE, Bluefish, vim and others. * Windows: Notepad++, ConTEXT, Notepad2. * OS X: Aquamacs. Note that if you use the UTF-8 encoding, you should save your files ''"without Byte Order Mark (BOM)"''. Over time PmWiki will be updated to default to Unicode/UTF-8 encoding, which allows all possible alphabets and languages. See UTF-8 for more information. pub/css/local.cssYou can create this file and set there some custom CSS styles which will override any styles set by skins. For example:
h1, h2, h3, h4, h5 { color: #880000; } /*dark red titles*/
a { text-decoration: none; } /* don't underline links */
CSS files are included in the order
# @@ Don't modify pmwiki.php or other core filesYou should strongly resist the temptation to directly modify the ''pmwiki.php'' script or the files in the ''scripts/'' subdirectory. Any modifications you make to these files will probably be overwritten whenever you upgrade. Instead, look at some of the sample scripts for examples of customizations that can be performed from ''config.php''. You can even create your own script to do a customization and use @@include_once(...)@@ to include it from ''config.php''. If you do make your own customization script, you can safely put it in the ''cookbook/'' subdirectory--it won't get overwritten by an upgrade there. You might also want to submit your customization to the pmwiki-users mailing list or the Cookbook so that others can benefit from your effort and so that it can perhaps be included in future releases of PmWiki. FAQ>>faq<< Q: There's no "config.php"; it's not even clear what a "local customisation file" is! A: The "sample-config.php" file in the "docs" folder, is given as an example. Copy it to the "local" folder and rename it to "config.php". You can then remove the "#" symbols or add other commands shown in the documentation. See also Group Customizations. Q: Can I change the default page something other than Main.HomePage ( -> Note the recommendations in Q: How do I get the group / page name in a local configuration file (e.g. ''local/config.php'')? A: Use the following markup in pmwiki-2.1.beta21 or newer: ## Get the group and page name $pagename = ResolvePageName($pagename); $page = PageVar($pagename, '$FullName'); $group = PageVar($pagename, '$Group'); $name = PageVar($pagename, '$Name'); Note the importance of the order of customizations in config.php above to avoid caching problems. If you need the verbatim group and page name (from the request) early in config.php, Q: Can I remove items from the wikilib.d folder on my site? A: The files named Site.* and SiteAdmin.* contain parts of the interface and the configuration and they should not be removed. The other files named PmWiki* contain the documentation and could be removed. Q: How do I customize my own 404 error page for non-existent pages? A: To change the text of the message, try editing the Site.PageNotFound page. Q: Is the order of customizations in config.php important? Are there certain things that should come before or after others in that file? A: Yes, see Order of the commands in config.php.(:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:LocalCustomizations, and a talk page: PmWiki:LocalCustomizations-Talk. >><< |
Page last modified on November 22, 2019, at 08:25 AM
