Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
GroupCustomizations(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) administrators (intermediate)
(:nl:)(:Summary: How to customize a subset of your wiki:)
(:Audience: administrators (intermediate) :) One of the purposes of Wiki Groups is to allow a Wiki Administrator to customize the features of PmWiki on a per-group basis. Here is where ''per group customizations'' come into play. Group-specific PHP and CSSThe ''local/'' subdirectory is used to hold local configuration files. The ''pub/css/'' subdirectory is used to hold local css files. To perform local customizations for a particular WikiGroup, * place the customizations in a file called "''<groupname>.php''" (where ''<groupname>'' is the actual name of the page group in question) in the ''local/'' subdirectory * place the CSS customizations in a file called "''<groupname>.css''" (where ''<groupname>'' is the actual name of the page group in question) in the ''pub/css/'' subdirectory. These files will be automatically processed after processing any local customizations in the ''config.php'' and ''local.css'' files. For example, to change the image displayed in the upper-left corner of pages in the "GroupName" WikiGroup, one could create ''local/GroupName.php'' containing -> <?php $PageLogoUrl = "/myimages/chess.gif";The example's effect would cause all pages in the GroupName Wiki Group to use "/myimages/chess.gif" as the logo image instead of the default. To add markup to the beginning or end of each page in a wiki group, see Group headers. Per-page customizationsPmWiki also allows per-page customizations; simply use the full name of the page to be customized instead of the group. For example, one can use the file ''local/Chess.HomePage.php'' to set local customizations for Chess.HomePage. Almost any customization that would be placed in ''config.php'' can be used as a per-group or per-page customization. An important exception to this is setting '''per-group or per-page customizations for recipe scripts''' included in config.php. Most recipe scripts would need any customization variables defined before the script is included. Instead of using a per-group or per-page customization php file, use a per-group or per-page conditional statement in config.php, before including the recipe script. Example: ->
## Inclusion of per-page and per-group local php scripts
$pagename = ResolvePageName($pagename);
include_once("$FarmD/scripts/pgcust.php");
<:vspace>
$page = PageVar($pagename, '$FullName');
$group = PageVar($pagename, '$Group');
//per-group customizations:
if($group=='GroupName') {
$RecipeVariable = 'valueA';
etc. ...
//per-page customizations:
if($page=='GroupName.PageName') {
$RecipeVariable = 'valueB';
etc. ...
//include recipe after variables are set:
include_once('cookbook/recipescript.php');
''Required reading: Order of the commands in config.php.''
Note that this method cannot be used to set Processing orderFor all local customizations, PmWiki first processes the ''local/config.php'' file, and then looks for a per-page customization file in the ''local/'' subdirectory to process, followed by any per-group customization file. If no per-page or per-group customizations are loaded, then PmWiki loads ''local/default.php''. If a per-page customization wants to have the per-group customizations loaded first, it can do so directly by using PHP's Custom CSS styles per group or per-pageTo apply CSS styles to pages of a specific group named Group Name?, create a file named ''GroupName.css'' in the ''pub/css/'' directory and add the CSS style rules there. To apply styles to a specific page, create a file ''GroupName.PageName.css'' in this directory with your style rules. Any CSS rules to be applied for all wiki pages can be put into ''pub/css/local.css''. ->
body { background: #F4C4B4; }
See also Preventing group-Level configurationsAny customization file can set AuthenticationAny passwords required for a group should be set in the group's Group Attributes? page (see Passwords Administration) and not in a group customization file. Consider Wiki FarmsWiki Groups are an easy way to host multiple sites in a single PmWiki installation by giving each site its own group. Another approach is to use Wiki Farms, which allows each site to have its own set of Wiki Group and local customization files. If you are looking for nested group levels, you may want to consider Pm's design considerations on hierarchical groups. FAQ>>faq<< Q: How can I apply CSS styles to a particular group or page? A: Simply create a ''pub/css/Group.css'' or ''pub/css/Group.Page.css'' file containing the custom CSS styles for that group or page. See also Cookbook:LocalCSS. Q: Why shouldn't passwords be set in group (or page) customization files? Why shouldn't group or page passwords be set in config.php? A: The reason for this advice is that per-group customization files are only loaded for the current page. So, if @@$DefaultPasswords['read']@@ is set in ''local/GroupA.php'', then someone could use a page in another group to view the contents of pages in GroupA. For example, Main.WikiSandbox could contain: --> (:include GroupA.SomePage:) and because the ''GroupA.php'' file wasn't loaded (we're looking at Main.WikiSandbox --> ''local/Main.php''), there's no read password set. The same is true for page customization files. Q: Isn't that processing order strange? Why not load per page configuration last (that is after global configuration an per group configuration)? A: Many times what we want to do is to enable a certain capability for a group of pages, but disable it on a specific page, as if it was never enabled. If the per-group config file is processed first, then it becomes very difficult/tedious for the per-page one to "undo" the effects of the per-group page. So, we load the per-page file before the per-group. If a per-page customization wants the per-group customizations to be performed first, it can use the techniques given above (using ''include_once()'' or setting @@$EnablePGCust = 0;@@). (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:GroupCustomizations, and a talk page: PmWiki:GroupCustomizations-Talk. >><< |
Page last modified on November 22, 2019, at 08:37 AM
