Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Internationalizations(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) PmWiki supports internationalization (internationalisation) of web pages, allowing accented characters to appear in page names and almost complete customization of PmWiki's prompts. Most customization is provided via the XLPage() function in PmWiki, which loads a set of translation variables from a wiki page (typically named XLPage, but it can be named anything you wish). The rest of this page is devoted to the installation, configuration and usage of other language(s) support. If you are looking for tools and help to ''localize'' PmWiki in your language, or how you can improve the existing translations, start on pmwiki.org with the page Localization - The Translation Portal. >>rframe font-size:smaller clear:right<< >><<Loading Translation PagesPages for many other languages have already been created and maintained at the pmichaud.com site. You can download an archive of these translations from http://www.pmwiki.org/pub/pmwiki/i18n/ . Simply download the appropriate language archive(s), and unpack the archive(s) into the directory containing your ''pmwiki.php'' installation. Each archive contains a number of page files that are placed in your ''wikilib.d/'' directory, and some special scripts for translations that use a character set other than iso-8859-1 (PmWiki's default). You can also use UTF-8 charset. Once the translation pages are installed, you enable a language by adding a call to XLPage() in your ''config.php'' file. For example, to select French language prompts, one would specify ->
include_once("scripts/xlpage-utf-8.php"); # optional
XLPage('fr','PmWikiFr.XLPage');
which says to load the translations for French ('fr') from the page PmWikiFr.XLPage?. The include_once line is recommended if you start a new wiki, and it should be placed ''before'' the XLPage line (for languages with alphabets other than the Latin, the include_once line is required). These lines should be placed near the beginning of config.php, ''but after any It's possible to load multiple pages; so if you want to create your own local translations without changing the ones you got from an i18n archive, just create another page (see below) and load it first. Be sure that you load first the page with your local changes: ->
XLPage('fr','PmWikiFr.XLPageLocal'); # my local translations
XLPage('fr','PmWikiFr.XLPage'); # from i18n.tgz
If your intention is to offer multiple languages on your site, and use Wiki Groups as language selectors, you may want to place this code in local customizations files (see Group Customizations). For example, if your site is published in French and English, and the French pages are in a group called Fr, you could create a file named Fr.php in the ''local/'' directory which contains: ->
<?php if (!defined('PmWiki')) exit();
##change to French language
You may wish to create a page called ''PmwikiFr.php'' with the same content to access the French documentation in the PmwikiFr group. ''En.php'' is not necessary in this case since English is the default language. An alternative to the above would be to add to ''config.php'' the following, which tests if there is an XLPage in a group, and if it finds one it gets loaded (any language): ->
$xlpage = FmtPageName('$Group.XLPage', $pagename);
if (PageExists($xlpage)) XLPage($xlpage, $xlpage);
With this method you would need to copy any relevant XLPage into any group which needs the different language support. Another way (advanced) would be insert into config.php this script, it asks to the web server the headers received from the user's browser and select a language; example with spanish and english: ->
$lang = substr($_SERVER['HTTP_ACCEPT_LANGUAGE'], 0, 2);
switch ($lang){
case "es":
XLPage('es','PmWikiEs.XLPage');
break;
case "en":
XLPage('en','PmWikiEn.XLPage');
break;
default:
break;
See also * Cookbook:MultiLanguage * Cookbook:MultiLanguageViews Creating New TranslationsIf language pages don't exist for your desired language, it's easy to create one! An XLPage translation file simply contains lines of the form -> where "phrase" is an internationalized phrase (denoted by -> converts " If you create new versions of PmWiki pages in other languages, please consider adding them to the main PmWiki site so that they can be made available to others in the i18n archives! (Be sure to check out The Localization Portal? for further information on effectively internationalizing PmWiki.) -> The term "i18n" is commonly used as an abbreviation for the English word "internationalization". The abbreviation is derived from the fact that there are 18 letters between the "i" and the final "n" and few people want to type them all out. Enabling "Special" Characters in WikiLinksTo enable "special" characters like for example German umlauts in WikiLinks, it is necessary to configure the server locale to ensure that PmWiki uses the proper character set definition. If this is not possible due to limited access to the server configuration, PmWiki can be configured to use a specific locale by using the XLPage options (see XLPageTemplate). For German umlauts, you'd need for example: * Note that the locale identifier depends on the operation system and perhaps on the specific installation. NotesQ: If my wiki is internationalized by ''config.php'', how do I revert a specific group to English? A: Use Q: If my wiki is in English and I want just one page, or group, in Spanish do I say A: Yes, that is usually the best method. If you were doing this with many scattered pages, or with several languages, you might find it easier to maintain if you load the translations all in config.php like this: XLPage('es','PmWikiEs.XLPage');
XLPage('ru','PmWikiRu.XLPage');
A: Then in each group or page configuration file, you'd just use Q: What does the first parameter of this function stand for? How can it be used? A: The XLPage mechanism allows multiple sets of translations to be loaded, and the first parameter is used to distinguish them. For example, suppose I want to have translations for both normal French and "Canadian" French. Rather than maintain two entirely separate sets of pages, I could do: XLPage('fr-ca', 'PmWikiFrCa.XLPage');
XLPage('fr', 'PmWikiFr.XLPage');
PmWikiFr.XLPage would contain all of the standard French translations, while PmWikiFrCA.XLPage would only need to contain "Canada-specific" translations -- i.e., those that are different from the ones in the French page. The first parameter distinguishes the two sets of translations.
In addition, a ''config.php'' script can use the and PmWiki will use only the 'fr' and 'en' translations (in that order), no matter how many translations have been loaded with XLPage(). Q: How can I add a translation for an individual string in a PHP file? A: Use the XLSDV() function to provide a translation for a specific (English) string. For instance, with this in config.php XLSDV('nl', array('my English expression'=>'mijn Nederlandse uitdrukking'));
any instance of the variable expression If you need to get a translation in a PHP file, use the $local_string = XL("my English expression");
But beware: XLPage() uses XLSDV() internally for its translation pairs, too, and only the first definition is accepted! Thus, if the Dutch XLPage already contains a translation and you want to override that, you need to use your XLSDV('nl',...) ''before'' calling the correspondent XLPage('nl',...). Otherwise, by using XLSDV() ''after'' XLPage() - e.g. within a recipe that is included later in config.php - your translation will only work as long nobody defines 'my English expression' in that XLPage. (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:Internationalizations, and a talk page: PmWiki:Internationalizations-Talk. >><< |
Page last modified on November 17, 2019, at 08:45 PM
