Recent Changes - Search:
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Functions
(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :)
admins (advanced)
(:nl:)(:Summary: How some of the functions in pmwiki.php work:)
(:Audience: admins (advanced) :)
>>rframe font-size:smaller clear:right<<
Table of Contents
*pmcrypt() *pmsetcookie() *PCCF() (deprecated) *PPRA() *PPRE() (deprecated) *Qualify() *PHSC() *PSS() *stripmagic() *FmtPageName() *Markup() *mkdirp() *MakeLink() *MakeUploadName() *SessionAuth() *IsAuthorized() *CondAuth() *RetrieveAuthPage() *RetrieveAuthSection() *UpdatePage() >><<
This page describes some of the internal workings of PmWiki by explaining how some of the functions in pmwiki.php work. For a more brief list/overview on functions useful to for instance cookbook writers, see Cookbook:Functions.
To use this functions you have to make sure that all relevant internal variables have been initialized correctly. See Custom Markup and Custom Actions for more information on how these functions are typically called via Markup() or $HandleActions[].
pmcrypt($password, $salt = null)
The pmcrypt() function is intended to be a safe replacement for the PHP 5.6+ crypt() function without providing a $salt, which would raise a notice. If a salt is provided, crypt() is called to check an existing password. If a salt is not provided, password_hash() will be called to create a cryptographically strong password hash.
pmsetcookie($name, $val="", $exp=0, $path="", $dom="", $secure=null, $httponly=null)
This function is intended as a replacement for setcookie(). It will automatically set the $secure and $httponly arguments if they are not set by the caller function and if $EnableCookieSecure and $EnableCookieHTTPOnly are enabled.
PCCF($php_code, $callback_template='default', $callback_arguments = '$m') Deprecated since PHP 7.2
The PCCF() function (''PmWiki Create Callback Function'') can be used to create callback functions used with preg_replace_callback. It is required for PHP 5.5, but will also work with earlier PHP versions.
The first argument is the PHP code to be evaluated.
The second argument (optional) is the callback template, a key from the global $CallbackFnTemplates array. There are two templates that can be used by recipe authors: * 'default' will pass $php_code as a function code * 'return' will wrap $php_code like "return $php_code;" (since PmWiki 2.2.62)
The third argument (optional) is the argument of the callback function. Note that PmWiki uses the '$m' argument to pass the matches of a regular expression search, but your function can use other argument(s).
PCCF() will create an anonymous (lambda) callback function containing the supplied code, and will cache it. On subsequent calls with the same $php_code, PCCF() will return the cached function name.
See http://php.net/create_function.
>>font-style=italic<< PHP 7.2 deprecates create_function() and future versions will remove it. If you need to migrate older code that used PCCF(), you can usually write regular functions and pass the function name where you previously passed the result of PCCF(). For example, suppose you had a pattern like this:
  '/(?<=^| )([a-z])/' => PCCF("return strtoupper(\$m[1]);"),
For PHP 7.2 compatibility, you can write a callback function:
  function my_callback($m) { return strtoupper($m[1]); }
then change the pattern to look like this:
  '/(?<=^| )([a-z])/' => 'my_callback',
See also: the recipe PccfToPcfOverride allows existing recipes to run on PHP 7 without causing deprecated create_function() messages. >><<
PPRA($array_search_replace, $string)
The PPRA() function (''PmWiki preg_replace array'') can be used to perform a regular expression replacement with or without evaluation, for PHP 5.5 compatibility.
Since PmWiki 2.2.56, PmWiki uses this function to process the following arrays: $MakePageNamePatterns, $FmtP, $QualifyPatterns, $ROEPatterns, $ROSPatterns, $SaveAttrPatterns, $MakeUploadNamePatterns. Any custom settings should continue to work for PHP 5.4 and earlier, but wikis running on PHP 5.5 may need to make a few changes.
The first argument contains the 'search'=>'replace' pairs, the second is the "haystack" string to be manipulated.
The 'replace' parts of the array can be strings or function names. If the 'replace' part is a callable function name, it will be called with the array of matches as a first argument via preg_replace_callback(). If not a callable function, a simple preg_replace() will be performed.
Previously, PmWiki used such constructs:
  $fmt = preg_replace(array_keys($FmtP), array_values($FmtP), $fmt);
It is now possible to use simply this:
  $fmt = PPRA($FmtP, $fmt);
Note that since PHP 5.5, the search patterns cannot have an /e evaluation flag. When creating the $array_search_replace array, before PHP 5.5 we could use something like (eg. for $MakePageNamePatterns):
  '/(?<=^| )([a-z])/e' => "strtoupper('$1')",
Since PHP 5.5, we should use this (will also work in PHP 5.4 and earlier):
Note that the /e flag should be now omitted, instead of '$0', '$1', '$2', we should use $m[0], $m[1], $m[2], etc. in the replacement code, and there is no need to call PSS() in the replacement code, as backslashes are not automatically added.
>>font-style=italic<< For PHP 7.2 and newer, instead of using PCCF() to create anonymous functions, we add a real function in our add-on, and then pass the function name as the pattern replacement (see example at PCCF, which will also work on PHP 4 and 5):
PPRE($search_pattern, $replacement_code, $string) Deprecated since PHP 7.2
The PPRE() function (''PmWiki preg_replace evaluate'') can be used to perform a regular expression replacement with evaluation.
Since PHP 5.5, the preg_replace() function has deprecated the /e evaluation flag, and displays warnings when the flag is used. The PPRE() function automatically creates a callback function with the replacement code and calls it.
Before PHP 5.5, it was possible to use such calls:
  $fmt = preg_replace('/\\$([A-Z]\\w*Fmt)\\b/e','$GLOBALS["$1"]',$fmt);
Since PHP 5.5, it is possible to replace the previous snippet with the following (also works before PHP 5.5):
  $fmt = PPRE('/\\$([A-Z]\\w*Fmt)\\b/','$GLOBALS[$m[1]]',$fmt);
>>font-style=italic<< For PHP 7.2 and newer, calling this function will raise "deprecated" notices. You need to rewrite your code to use preg_replace_callback, by moving the code into real functions:
  $fmt = preg_replace_callback('/\\$([A-Z]\\w*Fmt)\\b/', 'my_global_var_callback',$fmt);
  function my_global_var_callback($m) { return $GLOBALS[$m[1]]; }
Qualify($pagename, $text)
Qualify() applies $QualifyPatterns to convert relative links and references into absolute equivalents. This function is called by usual wiki markups that include text from other pages. It will rewrite links like [[Page]] into [[Group/Page]], and page (text) variables like {$Title} into {Group.Page$Title} so that they work the same way in the source page and in the including page. See also $QualifyPatterns and @@RetrieveAuthSection()@@.
PHSC($string_or_array, $flags=ENT_COMPAT, $encoding=null, $double_encode=true)
The PHSC() function (''PmWiki HTML special characters'') is a replacement for the PHP function htmlspecialchars.
The htmlspecialchars() function was modified since PHP 5.4 in two ways: it now requires a valid string for the supplied encoding, and it changes the default encoding to UTF-8. This can cause sections of the page to become blank/empty on many sites using the ISO-8859-1 encoding without having set the third argument ($encoding) when calling htmlspecialchars().
The PHSC() function calls htmlspecialchars() with an 8-bit encoding as third argument, whatever the encoding of the wiki (unless you supply an encoding). This way the string never contains invalid characters.
It should be safe for recipe developers to replace all calls to htmlspecialchars() with calls to PHSC(). Only the first argument is required when calling PHSC(), although authors may wish to call PHSC($string_or_array, ENT_QUOTES).
Unlike htmlspecialchars(), the PHSC() function can process arrays recursively (only the values are converted, not the keys of the array).
PSS($string)
The PSS() function (''PmWiki Strip Slashes'') removes the backslashes that are automatically inserted in front of quotation marks by the /e option of PHP's preg_replace function. PSS() is most commonly used in replacement arguments to Markup(), when the pattern specifies /e and one or more of the parenthesized subpatterns could contain a quote or backslash. ("PSS" stands for "PmWiki Strip Slashes".) -->From PM: PmWiki expects PSS() to always occur inside of double-quoted strings and to contain single quoted strings internally. The reason for this is that we don't want the $1 or $2 to accidentally contain characters that would then be interpreted inside of the double-quoted string when the PSS is evaluated. --->@@Markup('foo', 'inline', '/(something)/e', 'Foo(PSS("$1"))'); # wrong@@ --->@@Markup('foo', 'inline', '/(something)/e', "Foo(PSS('$1'))"); # right@@
Note, the extra slashes are only added by @@preg_replace@@ with an @@/e@@ modifier. The markup definitions with @@Markup_e()@@ do NOT need to use PSS() in the replacement strings. The new-type markup definitions with @@Markup()@@ and a simple function name as a replacement do NOT need to use PSS() inside the replacement function. If you migrate old markup rules to the new format, delete the @@PSS()@@ calls.
Example
This is a fictitious example where PSS() should be used. Let us assume that you wish to define a directive (:example:) such that (:example "A horse":) results in the HTML -> <div>"A horse"</div>. Here is how the markup rule can be created: ->
Markup('example', 'directives',
       '/\\(:example\\s(.*?):\\)/e',
       "Keep('<div>'.PSS('$1').'</div>')");
We need to use PSS() around the '$1' because the matched text could contain quotation marks, and the /e will add backslashes in front of them.
stripmagic($string)
This function should be used when processing the contents of $_POST or _GET variables when they could contain quotes or backslashes. It verifies get_magic_quotes(), if true, strips the automatically inserted escapes from the string.
The function can process arrays recursively (only the values are processed).
FmtPageName($fmt, $pagename)
Returns $fmt, with $variable and $[internationalisation] substitutions performed, under the assumption that the current page is pagename. See PmWiki.Variables for an (incomplete) list of available variables, PmWiki.Internationalizations for internationalisation. Security: not to be run on user-supplied data.
This is one of the major functions in PmWiki, see PmWiki.FmtPageName for lots of details.
Markup($name, $when, $pattern, $replace)
Adds a new markup to the conversion table. Described in greater detail at PmWiki.CustomMarkup.
This function is used to insert translation rules into the PmWiki's translation engine. The arguments to Markup() are all strings, where:
:$name: The string names the rule that is inserted. If a rule of the same name already exists, then this rule is ignored. :$when: This string is used to control ''when'' a rule is to be applied relative to other rules. A specification of "<xyz" says to apply this rule prior to the rule named "xyz", while ">xyz" says to apply this rule after the rule "xyz". See CustomMarkup for more details on the order of rules. :$pattern: This string is a regular expression that is used by the translation engine to look for occurences of this rule in the markup source. :$replace: This string will replace the matched text when a match occurs, or the function name that will return the replacement text.
Also see: PmWiki.CustomMarkup and Cookbook:Functions#Markup
MarkupToHTML($pagename, $str)
Converts the string $str containing PmWiki markup into the corresponding HTML code, assuming the current page is $pagename.
Also see: Cookbook:Functions#MarkupToHTML
mkdirp($dir)
The function mkdirp($dir) creates a directory, $dir, if it doesn't already exist, including any parent directories that might be needed. For each directory created, it checks that the permissions on the directory are sufficient to allow PmWiki scripts to read and write files in that directory. This includes checking for restrictions imposed by PHP's safe_mode setting. If mkdirp() is unable to successfully create a read/write directory, mkdirp() aborts with an error message telling the administrator the steps to take to either create $dir manually or give PmWiki sufficient permissions to be able to do it.
MakeLink($pagename, $target, $txt, $suffix, $fmt)
The function MakeLink($pagename, $target, $txt, $suffix, $fmt) returns an html-formatted anchor link. Its arguments are as follows:
 $pagename is the source page
 $target is where the link should go
 $txt is the value to use for '$LinkText' in the output
 $suffix is any suffix string to be added to $txt
 $fmt is a format string to use
If $txt is NULL or not specified, then it is automatically computed from $target.
If $fmt is NULL or not specified, then MakeLink uses the default format as specified by the type of link. For page links this means the $LinkPageExistsFmt and $LinkPageCreateFmt variables, for intermap-style links it comes from either the $IMapLinkFmt array or from $UrlLinkFmt. Inside of the formatting strings, $LinkUrl is replaced by the resolved url for the link, $LinkText is replaced with the appropriate text, and $LinkAlt is replaced by any "title" (alternate text) information associated with the link.
Also see: PmWiki:MakeLink and Cookbook:Functions#MakeLink
MakeUploadName($pagename, $x)
@@MakeUploadName()@@ simply takes a string @@$x@@ (representing an attachment's name) and converts it to a valid name by removing any unwanted characters. It also requires the name to begin and end with an alphanumeric character, and as of 2.0.beta28 it forces any file extensions to lowercase. This function is defined in @@scripts/upload.php@@ and only used when uploads are enabled.
SessionAuth($pagename, $auth=NULL)
@@SessionAuth()@@ manages keeping authentication via cookie-sessions. Session contains ever password or vaidated id and associated groups from previous calls.It adds elements passed by @@$auth@@ to session. It also writes every element saved in session to @@$AuthPw@@(passwords) and @@$AuthList@@(ids and groups).
IsAuthorized($chal, $source, &$from)
@@IsAuthorized@@ takes a pageattributesstring (e. g. "id:user1 $1$Ff3w34HASH...") in @@$chal@@. @@$source@@ is simply returned and used for building the authcascade (pageattributes - groupattributes - @@$DefaultPassword@@). @@$from@@ will be returned if @@$chal@@ is empty, because it is not checked before calling @@IsAuthorized()@@, this is needed for the authcascade. @@IsAuthorized()@@ returns an array with three values: @@$auth@@ @@1@@ - authenticated, @@0@@ - not authenticated, @@-1@@ - refused; @@$passwd@@; @@$source@@ from the parameter list.
CondAuth ($pagename, 'auth level')
CondAuth implements the ConditionalMarkup for (:if auth level:). For instance CondAuth($pagename,'edit') is true if authorization level is 'edit'. Use inside local configuration files to build conditionals with a check of authorization level, similar to using (:if auth level:) on a wiki page.
Note that CondAuth() should be called after all authorization levels and passwords have been defined. For example, if you use it with Drafts, you should include the draft.php script before calling CondAuth():
   $EnableDrafts = 1;
   $DefaultPasswords['publish'] = pmcrypt('secret');
   include_once("$FarmD/scripts/draft.php");
   if (! CondAuth($pagename, 'edit')) { /* whatever */ }
Best is to use CondAuth() near the bottom of your config.php script.
@@RetrieveAuthPage($pagename, $level, $authprompt=true, $since=0)@@
Pm words as said in http://article.gmane.org/gmane.comp.web.wiki.pmwiki.user/12493/match=retrieveauthpage%% where:
   $pagename   - name of page to be read
   $level      - authorization level required (read/edit/auth/upload)
   $authprompt - true if user should be prompted for a password if needed
   $since      - how much of the page history to read
                 0 == read entire page including all of history
                 READPAGE_CURRENT == read page without loading history
                 timestamp == read history only back through timestamp
The $since parameter allows PmWiki to stop reading from a page file as soon as it has whatever information is needed -- i.e., if an operation such as browsing isn't going to need the page's history, then specifying READPAGE_CURRENT can result in a much faster loading time. (This can be especially important for things such as searching and page listings.) However, if combined with UpdatePage, the updated page will have no history.
Use e.g. $page = @RetrieveAuthPage('Main.MyPage', 'read') to obtain a page object that contains all the information of the correspondent file in separate keys, e.g. $page['text'] will contain a string with the current wiki markup of Main.MyPage. Use this generally in preference to the alternative function ReadPage($pagename, $since=0) since it respects the authorisation of the user, i.e. it checks the authorisation level before loading the page, or it can be set to do so. ReadPage() reads a page regardless of permission.
Passing 'ALWAYS' as the authorization level (instead of 'read', 'edit', etc.) will cause RetrieveAuthPage to always read and return the page, even if it happens to be protected by a read password.
@@RetrieveAuthSection($pagename, $pagesection, $list=NULL, $auth='read')@@
RetrieveAuthSection extracts a section of text from a page. If $pagesection starts with anything other than '#', the text before the first '#' (or all of it, if there is no '#') identifies the page to extract text from. Otherwise RetrieveAuthSection looks in the pages given by $list (should be an array), or in $pagename if $list is not specified. * The selected page is placed in the global $RASPageName variable. * The caller is responsible for calling Qualify() as needed, i.e. if you need to control how unqualified page and variable names shall be resolved. ** To have them act as in the original text, let @@Qualify()@@ resolve them relative to the source page. ** If the imported text was not meant as wikitext but as some other kind of markup that might happen to contain double pairs of square brackets, (:comment <-- not: pairs of double square brackets = U+301A/U+301B:) or dollar signs inside curly brackets, you probably don't want to @@Qualify()@@ them. If you output them into wikitext, you'll probably need to @@Keep()@@ the text (:comment <-- translators: conceptually this means to have Keep() pack the text in a container that marks it as "final".:) (in case of HTML, XML, RSS or similar output, @@PHSC()@@ first!), to prevent later stages of processing from interpreting the apparent wiki markups in context of the target page. ** If your code produces wikitext for an auxiliary page that is meant to be included by another page higher up in the inclusion chain, and want links and variables to work as if they were in the auxiliary page, use the auxiliary page's "GroupName.PageName" as the $pagename argument for @@Qualify()@@.
Provides a way to limit the array that is returned by ReadPage, so that it only pulls the content up to a specific section marker. For example, pulling from start of page to '##blogend': ->
function FeedText($pagename, &$page, $tag) {
  $text = RetrieveAuthSection($pagename, '##blogend');
  $content = MarkupToHTML($pagename, $text);
  return "<$tag><![CDATA[$content]]></$tag>";
The '##blogend' argument says to read from the beginning of the page to just before the line containing the marker. See IncludeOtherPages for more information about the section specifications.
This version won't read text from pages that are read-protected; if you want to get text even from read-protected pages, then ->
  $text = RetrieveAuthSection($pagename, '##blogend', NULL, 'ALWAYS');
@@UpdatePage($pagename, $old (page object), $new (page object));@@
''More Technical Notes''
UpdatePage() allows cookbook recipes to mimic the behavior of editing wiki pages via the browser. Internally, PmWiki does several house keeping tasks which are accessible via this function (preserving history/diff information, updating page revision numbers, updating RecentChanges pages, sending email notifications, etc._ * "Page object" refers to an array pulled from RetrieveAuthPage($pagename, $level, $authprompt=true, $since=0); (preferred), or ReadPage($pagename); (disregards page security). Note that $new['text'] should contain all page data for the new version of the page. * If a page doesn't exist, UpdatePage() will attempt to create it. * Ignoring $old (e.g. UpdatePage($pagename, '', $new);) will erase all historical page data---a ''tabula rasa''. ** If you retrieved $old using RetrieveAuthPage($pagename,$auth,$prompt,READPAGE_CURRENT) and set $new=$old, then UpdatePage will also erase all historical data @@UpdatePage()@@ cannot be called directly from config.php because there are necessary initializations which occur later in pmwiki.php. It is not enough to just load stdconfig.php. If you want to use @@UpdatePage()@@ you will need to do it within a custom markup, a custom markup expression, or a custom action.
Categories: PmWiki Developer(:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :)
<<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:Functions, and a talk page: PmWiki:Functions-Talk. >><<
Page last modified on August 30, 2019, at 12:32 PM
