Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
Drafts(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) PmWiki has the capability to stage ''draft'' versions of a page prior to them becoming "official". All of the draft pages end in "-Draft" by default (this can be changed by setting Configuration and usageWhen the site administrator sets The "Save draft" button causes any edits to be saved to a "-Draft" copy of the original page, leaving the original page intact. Subsequent requests to edit the page (either the original or -Draft) bring up the draft copy for further editing. The "Publish" button saves back to the original non-Draft copy of the page, removing any -Draft page that may have been created. By default, saving drafts and publishing are available to anyone with 'edit' permissions (see Passwords). However, the site administrator can also set the When "publishing", how the page's history is handled depends on whether the administrator has set the Drafts and (All)RecentChangesBy default, using the "Save draft" or "Save draft and edit" button will be recorded to both Site.AllRecentChanges and Group.RecentChanges. Also after "publishing" a draft version an orphaned link to the "-Draft" page will remain. To disable on both Site.AllRecentChanges and Group.RecentChanges: -> $DraftRecentChangesFmt = array(); or alternatively: -> if ( @$EnableDrafts && @$_POST['postedit']>'' || @$_POST['postdraft']>'' ) unset($RecentChangesFmt); To only disable one of these, unset it individually: ->
if ( @$EnableDrafts && @$_POST['postedit']>'' || @$_POST['postdraft']>'' ) {
unset($RecentChangesFmt['$Group.RecentChanges']); # -and/or-
unset($RecentChangesFmt['$SiteGroup.AllRecentChanges']);
If a ->
$DraftRecentChangesFmt['Site.DraftRecentChanges']
= '* [[{$Group}.{$Name}]] . . . $CurrentTime $[by] $AuthorLink: [=$ChangeSummary=]';
See also Drafts with searches, pagelists, and RSSThe drafts module also sets pagelists and searches (and thus RSS feeds) to ignore "-Draft" pages by default; one has to do list=all or similar in order to have draft pages included in a pagelist or RSS feed. Q: How do I moderate all postings? A: Start by enabling drafts to change the "Save" button into separate "Publish" and "Save draft" buttons. Then set |
Page last modified on November 21, 2019, at 09:17 PM
