Recent Changes - Search:
<^< The Flowcode Process | Course index | Different Types of PICmicro >^>
About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming ## What is a Program? ## The Flowcode Process ##
Running the Program ## Different Types of PICmicro * 16F1937 Architecture
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Running the Program
<^< The Flowcode Process | Course Index | Different Types of PICmicro >^>(:nl:)
As soon as the PICmicro is powered up, and has a clock, it will start to run whatever program is stored in program memory (Flash).
If you press the reset button on your PICmicro programming board, then the program will restart from the beginning.
During programming the PICmicro stops whilst the program is being loaded, but once it is in the PICmicro, it will then restart and run the downloaded program. (:nl:)(:table style="clear:both":)
Page last modified on September 19, 2011, at 12:48 PM
