Recent Changes - Search:
<^< Darlington Driver | Course index | Introduction and Lesson Plan >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers ## Transistor Switch ## Darlington Driver ##
7-Segment Decoder Driver
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Darlington Driver | Course Index | Introduction and Lesson Plan >^>(:nl:)
You can run a 7-segment display directly from the PICmicro chip. However, that would take up seven bits of the PICmicro output port, one for each LED in the display. In some applications, that may not leave sufficient bits to operate other devices.
An alternative is to use a decoder/driver chip to do some of the work. This would use only four output bits. This chip accepts a binary input, (well, binary-coded decimal to be more precise,) and converts it into the seven signals needed to control the display. The 'driver' part of its name shows that it draws little current from the PICmicro to do so.
The CMOS 4511 chip is a 7-segment decoder/driver, used with common-cathode displays. The pin out for this chip is given in the diagram.
The inputs D, C, B and A, accept the binary number. This must be supplied the right-way round! Input D expects the most significant bit of the number, and input A the least significant bit. The following table illustrates the point.
Decimal 4511 inputs
NumberDCBA
10001
30011
50101
81000
The 4511 has three control inputs that allow you to:
* test the chip and display, by connecting the 'LT' (Lamp Test) input to 0V. This should cause all segments of the display to light up. * switch off all segments of the display, by connecting the 'BI' (Blank Inputs) input to 0V. * 'freeze' the display, and ignore any changes in the binary number applied to the input, by connecting the 'ST' (STore) input to the positive supply rail.
All of these functions can be integrated into the PICmicro program itself, in which case you disable them on the 4511, by connecting 'LT' and 'BI' to the positive supply rail, and 'ST' to 0V. The next diagram shows a 4511 connected to a 7-segment display, with the control functions disabled. Notice the protective 330ohm resistor!
(:nl:)(:table style="clear:both":)
Page last modified on January 30, 2012, at 03:20 PM
