Recent Changes - Search:
<^< Saving a Flowchart | Course index | Zooming the View >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions ## What is Flowcode? ## Flowcode Overview ## Start a New Flowchart ## Opening an Existing Flowchart ## Saving a Flowchart ##
Saving Flowchart Images ## Zooming the View ## Printing Flowcharts ## View Options * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Saving a Flowchart | Course Index | Zooming the View >^>(:nl:)
To save an image of the currently active flowchart select 'Save current Flowchart...' from the 'Save Image' sub-menu in the 'File' menu (File > Save Image > Save current Flowchart...).
This function saves an image of the program to any file in the format chosen from the list: *Bitmap (*.bmp) *JPEG (*.jpg;*.jpeg) *GIF (*.gif) *PNG (*.png)
Note that the current zoom rate is used to determine the resolution of the image saved. If you need high quality images for printing then increase the zoom rate.
From the 'Save Image' menu you also have the option to save the current image on either the 'Dashboard Panel' or the 'System Panel' (File > Save Image > Save Dashboard image... / Save System image...).
These images can be saved to any file format chosen from the list: *Model (*.mesh) *Bitmap (*.bmp) *JPEG (*.jpg;*.jpeg) *GIF (*.gif) *PNG (*.png)Model (*.mesh)(:nl:)(:table style="clear:both":)
Page last modified on May 28, 2013, at 09:01 AM
