Recent Changes - Search:
<^< Saving Flowchart Images | Course index | Printing Flowcharts >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions ## What is Flowcode? ## Flowcode Overview ## Start a New Flowchart ## Opening an Existing Flowchart ## Saving a Flowchart ## Saving Flowchart Images ##
Zooming the View ## Printing Flowcharts ## View Options * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Zooming the View
<^< Saving Flowchart Images | Course Index | Printing Flowcharts >^>(:nl:)
As you develop larger programs you will want to display more icons in a window than the default zoom setting allows. To do this you can change the zoom setting of each flowchart in your program. The current zoom setting is displayed on the Zoom sub menu, and on the right hand side of the status bar at the bottom of the Flowcode window. The zoom parameters and options can be seen when you select 'View' and then select 'Zoom' to open submenu (View > Zoom >).
There are several shortcuts to this menu available via function keys:
* Increase Zoom (F3) - increases zoom size by 5% * Decrease zoom (F2) - decreases zoom size by 5% * Default zoom (F4) - set zoom to 75%
* Zoom to fit - Zooms to fit the whole flowchart into the current window. * Zoom to fit width - Zooms to fit the width of the flowchart into the width of the window.
Right-click zoom function
You can also access a zoom menu by right-clicking on the workspace in each Flowchart window.(:nl:)(:table style="clear:both":)
Page last modified on May 07, 2013, at 07:50 AM
