Recent Changes - Search:
<^< Building Circuits with PICmicro's | Course index | E-blocks Prototyping Boards >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods ## Building Circuits with PICmicro's ##
Prototype Board ## E-blocks Prototyping Boards ## Stripboard ## Printed Circuit Board * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Prototype Board
<^< Building Circuits with PICmicro's | Course Index | E-blocks Prototyping Boards >^>(:nl:)
A prototype board, also called a 'breadboard' is the quickest and cheapest way to set up a circuit. The picture shows one type of prototype board.
Underneath the rows of holes, sets of metal clips connect together the components used in the circuit. The next photograph shows the back view of the board.
Metal clips
When you push the leg of a component through a hole in the prototype board, it is gripped by a metal clip. This clip runs beneath all the holes in that row on the board. When two components are plugged into the same row, the clip grips them both and makes an electrical connection between them.
Advantages
* quick to assemble; * no health and safety issues about soldering; * cheap, because components can be re-used.
Disadvantages
* not mechanically robust; * relatively bulky * final component layout can be difficult to relate to the circuit diagram.
(:nl:)(:table style="clear:both":)
Page last modified on August 25, 2011, at 03:51 PM
