Recent Changes - Search:
<^< The Digital World | Course index | Analogue Data >^>
About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue ## The Digital World ##
The Analogue World ## Analogue Data ## Digital Data ## Analogue to Digital Conversion * Inputs and Outputs * Memory * Programming * 16F1937 Architecture
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
The Analogue World
<^< The Digital World | Course Index | Analogue Data >^>(:nl:)
Now the information is given in the form of an analogy! In other words, we use something that behaves in a similar way. Here are some examples.
The hour glass egg timer
The greater the time interval, the deeper the sand in the bottom of the egg timer.
The mercury-in-glass thermometer
The hotter it gets, the further the mercury moves up the tube.
The car speedometer
The higher the speed, the further round the dial the pointer moves. The problem is that you have to do some work to extract the data. In the case of the speedometer, and the thermometer, you have to work out where the pointer sits on the scale.
On the other hand, you can easily judge how the temperature of a body is changing by watching how quickly the mercury is moving along the tube. (:nl:)(:table style="clear:both":)
Page last modified on August 19, 2011, at 10:24 AM
