Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login PmWiki /
BlockMarkup(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :) "Block markup" is a term used in the sources of PmWiki indicating all markups resulting in HTML block elements'^[1]^' or in other words multiple paragraphs and other content. * Forms * paragraphs * indent/outdent * lists * list items * headings * divisions and semantic HTML5 elements * images * pre * tables WikiStyles can be applied to blocks, else you don't need to bother about "blockmarkup" as a PmWiki user. Division blocksDivision <div> HTML blocks are inserted with the (:div:) Outer block (:div2:) Inner block (:div2end:) (:divend:) Semantic HTML5 elementsSince version 2.2.75, PmWiki allows the inclusion of a few semantic HTML5 elements. Note that an opening semantic markup automatically closes any previously opened tag of the same type, but does not verify or tidy the structure for you, so make sure you use closing tags when needed. : (:article:) Outer article (:article2:) Inner article (:article2end:) (:articleend:) : : : : : : :
: : To have a details section open by default, add the attribute @@open=open@@ like See also* BlockMarkup Markup resulting in paragraphs * ConditionalMarkup The if directive allows portions of a page to be included or excluded from rendering * CustomMarkup Using the Markup() function for custom wiki syntax; migration to PHP 5.5 * MarkupExpressions String and formatting operations * Markup Master Index Tabulation of all PmWiki markup (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :) <<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:BlockMarkup, and a talk page: PmWiki:BlockMarkup-Talk. >><< |
Page last modified on June 07, 2020, at 01:07 AM
