Introduction to Microcontroller Programming
* Course Index
* Introduction
* About the Author
* About this Course
* Feedback
* Course Navigation
* Quick Course Navigation
* How to use this Course
* Acronyms Used and Course Conventions
About PICmicro Chips
* What is a PICmicro?
* Microcontrollers
* Digital versus Analogue
* Inputs and Outputs
* Memory
* Programming
* 16F1937 Architecture
Clocking Your PICmicro Devices
* Introduction
* The Clock Circuit
* Clock Settings
* Clock Confusion
E-Blocks
* Introduction to E-blocks
* Using E-blocks
* E-blocks Boards
Flowcode Step By Step
* Introduction to Flowcode
* Basic Flowcode Functions
* Digital Outputs
* Digital Inputs
* Basic Loops
* The LCD Display
* Binary Numbers
* Decisions
* Goto (Connection Point)
* 7-Segment Displays
* Software Macro
* Strings and Memory
* A Simple Hi-Fi
PICmicro Projects
* Introduction to PICmicro Projects
* Construction Methods
* Choosing a Power Source
* Adding Inputs
* Input Conditioning
* Adding Outputs
* Adding Drivers
Labs
* Introduction and Lesson Plan
* 1. Output
* 2. Delay
* 3. Connection Point
* 4. Calculations
* 5. Loop
* 6. Input
* 7. Decision
* 8. LCD
* 9. Keypad
* 10. Analogue + EEPROM
* 11. Software Macro
* 12. External Interrupt
* 13. Timer Interrupt
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:)
(:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :)
* Print
(:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:)
* %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]]
(:ifend:) :)
* Login
(:Summary: PmWiki group header. Includes styles and trail.:)
(:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:)
(:comment included in PmWiki localisation headers and footers :)
(:nl:)
(:Summary:Tabulation of all PmWiki markup:)
This page contains the most frequently used wiki markup, briefly. Follow the links in each section to learn more.
Markup concepts introduction
PmWiki markup can be applied to 'blocks' of text, and to text 'lines'.
PmWiki markup is also used to read and save page, group, and wiki metadata through the use of variables.
PmWiki markup can be used to process metadata variables though expressions and pagelists.
PmWiki provides a wiki style markup that can be applied to text, lists?, paragraphs, and blocks.
Text markup, also known as wikitext is variable, see below, and in general broadly follows wiki conventions.
Text markup only applies to single lines of text, delimited by a newline.
Block markup is applied to multiple lines of text as paragraph blocks and division blocks.
In PmWiki the most important markup is the directive.
The directive is signified by parenthesis and a colon, viz: (:...:).
The directive provides most of PmWiki's functionality.
Markup expressions {(...)}, variable markup {$...}, and wiki styles %...% also provide PmWiki functionality.
Links
See Links
External links
-< http://example.com
-< [[http://example.com]]
-< [[http://example.com"tool tip"]]
-< [[http://example.com | link text]]
-< [[link text -> http://example.com]]
Use [=link address=] to escape any special characters, including quotes, spaces, parentheses and pipes.
Page links
-< [[PageName]]
-< [[page name]]
-< [[page (name)]]
-< [[PageName | link text]]
-< [[PageName | + ]] ''(titled link)''
-< [[PageName | # ]] ''(anonymous numerical reference link)''
-< [[PageName"tool tip"]]
-< [[link text -> PageName]]
-< [[#anchor]] ''(to create an anchor)''
-< [[#anchor | link text]] ''(to refer to an anchor)''
-< [[anchor | # ]] ''(anonymous numerical reference link)''
-< [[PageName#anchor | link text]] ''(to refer to an anchor in another page)''
See also WikiWord on how to enable WikiWord links.
WikiGroup links
See Links and Categories
-< [[GroupName/]] or [[Group name/]]
-< [[GroupName"tool tip"]]
-< [[GroupName.]]
-< [[GroupName/PageName]] or [[GroupName/page name]]
-< [[(GroupName.)page name]]
-< [[~Author Name]]
-< [[~Author Name | +]]
-< [[~Author Name | #]]
-< [[~Author Name | link text]]
-< [[~Author Name"tool tip"]]
-< [[!Category Name]]
InterMap links
See InterMap
-< [[Path:/path/local_document.html]]
-< [[Wikipedia:WikiWikiWeb]]
Email links
-< mailto:someone@example.com
-< [[(mailto:)someone@example.com]]
-< [[mailto:someone@example.com | display text]]
-< [[display text -> mailto:someone@example.com]]
Upload links
See Uploads and Images
-< Attach:file.odt
-< [[(Attach:)file.odt]]
-< [[Attach:file.odt | alternative text ]]
-< [[Attach:file with spaces.pdf]]
-< [[Attach:Groupname./file with spaces.pdf]]
In addition to @@http:@@, @@https:@@, @@@@ PmWiki also supports:
-< @@ftp:@@
-< @@news:@@
-< @@gopher:@@
-< @@nap:@@
-< @@file:@@
-< @@tel:@@
-< @@geo:@@
Images
See Images and Uploads
Images as Images
-< http://example.com/image.gif
-< http://example.com/image.gif"alt text"
-< Attach:image.gif"My image"
-< Attach:Groupname./image.gif"image in another group"
-< Attach:Groupname.Pagename/image.gif"image on another page"
-< %lfloat% Attach:image.gif | Caption %% ''(could be %rfloat%, %center%, %rframe%, %lframe%, %frame% )''
-< %width=200px% Attach:image.gif %%
-< %thumb% Attach:image.gif %%
Images as links
-< [[Attach:image.gif]]
-< [[(Attach:)image.gif]]
-< [[PageName | Attach:image.gif"alt text"]]
-< [[http://example.com/ | Attach:image.gif"alt text"]]
-< [[http://example.com/ | http://example.com/image.png"alt text"]] | Caption
-< %rframe thumb% [[Attach:image.gif | Attach:image.gif"alt text"]] | Caption
Start-of-line markup
See Text formatting rules
See List styles, Wiki styles and Cookbook:Outline lists
-< * unordered list
-< ** deeper list
-< # ordered list
-< # %item value=#% arbitrary start number
-< # %decimal%, %roman%, %ROMAN%, %alpha%, %ALPHA%
-< %comment%
-< :term:definition
Also
-< Q: start a question paragraph
-< A: start an answer paragraph
Headings
-< !! Heading
-< !!! Deeper heading
Paragraph blocks
-< -> indented text
-< -< hanging indent
-< <space> preformatted text
-< @@[@...@]@@ preformatted block
-< ---- (horizontal rule)
-< blank line is vertical space
-< \ at end of line joins next line
-< \\ at end of line produces a line break
-< \\\ at the end of a line produces a blank line, even within a list item, n backslashes will produce n-1 blank lines
-< [[<<]] produces a line break that clears floating content
Division blocks
See Block markup, Wiki styles and Page directives
-< >>wikistyle<<
-< (:div class="" style="":)
-< (:divend:)
-< >>comment<<
Text markup
Character format
-< ''emphasized''
-< '''strong'''
-< '''''strong emphasis'''''
-< @@monospaced@@
-< [-small-], [--smaller--]
-< [+big+], [++bigger++]
-< '-small-', '+big+'
-< '^superscript^', '_subscript_'
-< {+inserted+} (underscore)
-< {-deleted-} (strikethrough)
-< @@[@escaped code@]@@
-< [=escaped text=]
Posting markup
-< @@~~@@@@~@@ (author's signature)
-< @@~~@@@@~~@@ (author's signature and date)
-< @@(:encrypt ''phrase'':)@@ -- replaced with encrypted form of ''phrase''
Tables
Plain rows and columns of text
See Tables
-< ||table attributes
-< ||!table caption!||
-< ||left aligned || centered || right aligned||
-< ||!column heading||
-< ||spanned columns ||||||
Structured tables
See Table directives
-< (:table attr:)
-< (:cellnr attr:)
-< (:cell attr:)
-< (:tableend:)
Directives
Page directives
See Page directives
-< (:redirect PageName:)
-< (:(no)spacewikiwords:)
-< (:(no)linkwikiwords:)
-< (:(no)linebreaks:)
Display
See Page directives Group headers
-< (:noheader:), (:nofooter:)
-< (:notitle:)
-< (:noleft:), (:noright:)
-< (:nogroupheader:), (:nogroupfooter:)
-< (:noaction:)
Metadata
See Page directives, Comment markup, Page variables
-< (:title text:)
-< (:keywords word, ...:)
-< (:description text:)
-< (:comment text:)
-< {Group/PageName$:variable} includes from (:variable:text:)
Include
See Include other pages, Page text variables
-< (:include PageName:)
-< (:include PageName#start#end lines=n paras=n:)
-< (:include Page1 Page2 Page3:)
-< {Group/PageName$:Var} includes from (:name:text:)
-< (:nl:) separate included text by conditional line break
Conditional markup
See Conditional markup
-< (:if (!) ''cond param'':)...(:ifend:)
-< (:if (!) ''cond param'':)...(:else:)...(:ifend:)
-< (:if (!) ''cond param'':)...(:elseif (!) ''cond param'':)...(:ifend:)
Pagelists
See Page lists
-< (:searchbox label=label order=-time:)
-< (:searchresults incl -excl group=abc fmt=def:)
-< (:pagelist incl -excl group=abc fmt=def:)
Other directives
See Page directives
-< (:toc:)
-< (:attachlist:)
-< (:PageDirectives#markup:) [=...=]
-< (:markup:)...(:markupend:)
-< (:markup class=horiz:)...(:markupend:)
-< (:markup caption='...':)...(:markupend:)
-< (:messages:)
Forms
See Forms
-< (:input form method=get action=url enctype=multipart/form-data:)
--< (:input default name=xyz value="abc":)
--< (:input text name=first value="Bob" size=20:)
--< (:input textarea name=xyz [=value=] rows=2 cols=80:)
--< (:input submit name=post value="Go" accesskey=g:)
--< (:input reset:)
--< (:input hidden name=action value=edit:)
--< (:input radio name=xyz value="abc" checked=1:)
--< (:input checkbox name=xyz value="abc" checked=1:)
--< (:input password name=authpw:)
--< (:input file name=upload:)
--< (:input image name=xyz src="http:..." alt="Alt Text":)
--< (:input select name=xyz value="val1" label="Value 1":)
--< (:input select name=xyz value="val2" label="Value 2":)
-< (:input end:)
See also PmWiki Edit forms.
Wiki trails
See Wiki trails
-< <<|[[TrailPage]]|>>
-< <|[[TrailPage]]|>
-< ^|[[TrailPage]]|^
Page variables
See Page variables, Page text variables, Page lists
-< {''$variable''}, {''pagename$variable''}, {''groupname.pagename$variable''}
-< {''$:variable''}, {''pagename$:variable''}, {''groupname.pagename$:variable''}
Set a page text variable
-< (:name:description:)
-< :name:description
-< name:description
See special references
-< {''*$variable''}
-< {''*$:variable''}
Page list templates special variables
-< {''=$variable''}, {''<$variable''}, {''>$variable''},
-< {''=$:variable''}, {''<$:variable''}, {''>$:variable''},
Expressions
See Markup expressions
-< {(''function args'')} (:nl:)(:Summary:Trail and talk page links:)
>>bgcolor=#ffe border-top="1px solid black" font-size=.8em<<
This page may have a talk page: PmWiki:MarkupMasterIndex-Talk.
