Recent Changes - Search:
<^< Strings and Memory | Course index | Set up the Equipment >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory ##
Introduction ## Set up the Equipment ## Exploring the Keypad ## Using String Variables ## ASCII ## Seeing ASCII ## Getting a Phone Number ## You try it ## EEPROM * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Introduction
<^< Strings and Memory | Course Index | Set up the Equipment >^>(:nl:)
In this section we will take a look at the EEPROM (Electrically Erasable Read Only Memory) function inside Flowcode.
Specifically you will learn:
* How to use the keypad to get a number or the ASCII equivalent * How to use a string to store a series of numbers * How to get users to input data into an E-blocks system * How to write data to the EEPROM * How to read data from the EEPROM (:nl:)(:table style="clear:both":)
Page last modified on August 25, 2011, at 11:07 AM
