Recent Changes - Search:
<^< Getting a Phone Number | Course index | EEPROM >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory ## Introduction ## Set up the Equipment ## Exploring the Keypad ## Using String Variables ## ASCII ## Seeing ASCII ## Getting a Phone Number ##
You try it ## EEPROM * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
You Try It
<^< Getting a Phone Number | Course Index | EEPROM >^>(:nl:)
Having described how this works; now it is your turn.
At this stage you will hopefully have enough knowledge about how Flowcode works so that we do not need to tell you what to enter on an icon by icon basis. You may struggle a little with this first example - but you will learn more in the process. (:nl:)(:table style="clear:both":)
Page last modified on January 30, 2012, at 03:04 PM
