Recent Changes - Search:
<^< Setting up the LCD | Course index | Finishing Touches >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi ## Introduction ## Set up the Equipment ## Port B Interrupts ## Setting up the LCD ##
Using the ADC ## Finishing Touches
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Using the ADC
<^< Setting up the LCD | Course Index | Finishing Touches >^>(:nl:)
So far you have set up two interrupts, and three macros which are called from the main routine. In this next part of the project you will set up a further macro that will measure the signal on an analogue input.
# Add an ADC component onto your project panel. Alter the connection so that it is connected to ADC 1 - this is the potentiometer on the Sensor board. # Add a new macro and call it 'ADCmeasure'. # Add a Component macro to the 'ADCmeasure' macro. Set it to 'GetInt' to read the value of the ADC into the variable 'ADCreading' that you set up previously. # Drag a Calculation icon into the macro and enter 'volume = ADCreading / 10' into the Calculation field.
You should have something like this:
The process of sampling the ADC is a two stage one: first sample the value and then read the value into a variable. The PICmicro we are using here actually has up to 8 ADC inputs - AN0 to AN8. Internally however the PICmicro only has one Analogue to Digital Converter. Each of the 8 inputs can be switched to the ADC using internal analogue switches. This gives you a clue as to why the process of getting an analogue input into your program is a two stage process: internally Flowcode sets up the analogue switch to connect to the relevant input, then it takes a reading.
The ADC inside the PICmicro has a resolution of 10 bits. This means that to make use of the full range of the ADC you need to use a variable of type Int: a 16 bit variable. The value you read will vary between 0 and 1023. However we are used to seeing Volume presented as 0 to 10, or 0 to 100. Because of this we can quickly divide the ADC reading by 10 to get a scale of 0 to 102 as our volume setting. You should by now be able to think of programming techniques to cap the value at 100. (:nl:)(:table style="clear:both":)
Page last modified on May 02, 2013, at 02:27 PM
