Recent Changes - Search:
<^< Switch Unit | Course index | Sensing Units >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs ## Switches ## Switch Unit ##
Sensors ## Sensing Units * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Sensors
<^< Switch Unit | Course Index | Sensing Units >^>(:nl:)
An electronic control system knows nothing about the outside world unless we give it sensors - its eyes, ears etc. The language it understands is that of electrical signals, voltages and currents.
A sensor has to turn changes in the outside world, such as light level, temperature, sound level, humidity, pressure etc., into changing electrical signals. A different type of sensor is needed for each of these tasks.
Here are some of them.
Light sensor:
The light dependent resistor (LDR) - Its resistance drops when a brighter light shines on it. It is relatively slow to react to changes in light level, though.
The photodiode - A component that passes an electric current only when sufficient light shines on it. It reacts much faster than the LDR to changes in light level.
Temperature sensor:
The thermistor - There are two versions of thermistor. One type, called ntc (negative temperature coefficient) has a resistance that gets less when its temperature goes up. The other type, ptc, (positive temperature coefficient) has a resistance which gets bigger when the temperature rises.
Sound sensor:
The microphone - The common form of microphone generates a voltage when it picks up a sound. The louder the sound, the bigger the voltage!
(:nl:)(:table style="clear:both":)
Page last modified on August 26, 2011, at 09:42 AM
