Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs ## Switches ## Switch Unit ## Sensors ## Sensing Units * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Switches<^< Adding Inputs | Course Index | Switch Unit >^>(:nl:) One of the most useful input devices! You can use a switch: * to start a sequence of events, such as a lighting display * to start, and later stop, a stopwatch program * to input pulses for a control system to count - the number of laps completed by a runner for example * to act as a sensor to trigger an alarm when a door is opened. Switches are manufactured in a number of different forms. Here are some: Momentary acting (push switch)For example, the switch on a doorbell, which causes something to happen only while it is being pressed. ![]() Toggle switchFor example, a light switch, which switches on (and stays on) the first time it is pressed, and switches off the next time. ![]() Tilt switchThis switches on when the body of the switch is tilted to a certain angle, or beyond. ![]() Rotary switchFor example, the selector switch on a hi-fi system, which you use to switch between the tape-deck, the CD deck and the radio tuner. To operate it, you turn a knob attached to the spindle of the switch. ![]() Key switchFor example, the switch used in a car ignition circuit, which operates only when the correct key is inserted. ![]() Magnetic switchThis switches on when a magnet is placed next to the switch, and off when the magnet is moved away again. ![]() (:nl:)(:table style="clear:both":)
Page last modified on August 26, 2011, at 09:37 AM
