Recent Changes - Search:
<^< Batteries | Course index | Rechargeable Batteries >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source ## Choosing a Power Source ## Batteries ##
Primary Batteries ## Rechargeable Batteries ## Mains Power Supply Units * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Primary Batteries
<^< Batteries | Course Index | Rechargeable Batteries >^>(:nl:)
Zinc-carbon batteries Alkaline manganese batteries
A review:
Battery type Advantages Disadvantages
Zinc-carbon 'regular-duty' Least expensive Lowest energy density*
Widely available Sloping discharge curve**
Poor high-current performance
Poor low-temperature performance
Zinc-chloride 'heavy-duty' Less expensive than alkaline. Low energy density*
Better than zinc-carbon at high current and low temperature Sloping discharge curve**
Last 25-50% longer than zinc-carbon
Alkaline manganese 'alkaline' Moderate cost Sloping discharge curve**
Moderate energy density*
Better than zinc chloride at high current and low temperature
Widely available
Last ~8 times longer than zinc-carbon
Lithium oxyhalide 'lithium' Highest energy density Expensive
Light weight
Horizontal discharge curve**
Excellent temperature performance
Very long shelf life
*Energy density is a measure of how much energy can be extracted from a battery per unit of battery weight or volume. Energy density should be as high as possible. **Discharge curve shows how the battery voltage drops as the battery ages with use. The ideal shape is a horizontal line
Summary:
* Forget zinc-carbon and zinc-chloride batteries! * If your control system drives a motor, you must use alkaline or lithium batteries * If a constant supply voltage is needed, use a lithium battery
(:nl:)(:table style="clear:both":)
Page last modified on August 26, 2011, at 09:17 AM
